h22 vafc hack setting questions
Old Sep 16, 2003 | 11:18 PM
Kp_VtekNiks's Avatar
Default h22 vafc hack setting questions
i got a h22 with a drag turbo, dsm 450cc, on there with a vafc hack. is there anyone else with this setup? if so i was wondering what ur settings were. -40 all through isnt working for me, it runs really lean. so right now i have it at +30 at boost and at -37 at idle. it idles pretty rough and the revs fluxuate. but other than that car runs pretty decent. boost kicks in well, but could be better. only pushin about 7psi. any ideas would be great thanks!!
i seem to be the only one here thats at + here with the fuel. everyone else to be on negative. so a lil worried over here.
Modified by Kp_VtekNiks at 9:47 AM 9/17/2003
Old Sep 17, 2003 | 12:46 AM
Default Re: h22 vafc hack setting questions (Kp_VtekNiks)
ttt
Old Sep 17, 2003 | 02:24 PM
no one has h22 turbo vafc hack?
Old Sep 17, 2003 | 04:02 PM
ki11a8ee's Avatar
mine is set at: 1-4k -36 5k -37 6-7k -36 8k -35 u have to remmember every car is different. The best way to get it right is to take it to a dyno or get a wideband with an air and fuel guage hooked up. Also make sure ur sensor setting is at 6 in 6 out and the throttle% 98 lo 99 high.
Old Sep 17, 2003 | 04:06 PM
Alstare's Avatar
Default Re: h22 vafc hack setting questions (ki11a8ee)
Those are basically the same settings i was running... it ran like shyte... The default basemap that came with my Aem EMS that barely idles runs 10000x better then the hack ever did for me though...
Try and save up for some real engine management asap you'll be amazed at the difference..
Old Sep 18, 2003 | 05:00 PM
thaks for sharing, i know everyone's setup is diffrent, i just thought it was extremly odd that i was in the + with fuel while everyone else is in the -. getting it tunded tomorrow anyway. more infor would be great. thanks
Old Sep 18, 2003 | 05:02 PM
Tinker219's Avatar
I had to run a +26 to keep my plugs from getting white too late though, already popped #'s 2 and 4.
Old Sep 18, 2003 | 05:23 PM
Cruiser G's Avatar
If your running in the positive side of the correction, you should be throwing a map code when you hit boost. Do you have a check engine light?
Old Sep 18, 2003 | 05:29 PM
Tinker219's Avatar
Default Re: h22 vafc hack setting questions (Cruiser G)
Yep, also 6 check valves...lol. runs great, took down an auto C5 convertible WITH TWO BLOWN cylinders, both pushing under 100 psi compression Wish I had a video of the guys face...then his face dissappearing behind the clouds of blue smoke...lol
Old Sep 19, 2003 | 12:38 AM
no check lights, me and my friend were also wondering why there isnt a cel for map.
Old Sep 19, 2003 | 01:36 AM
safe driver's Avatar
low settings at -40 all the way
high settings at:
1000 -40
1600 -35
2200 -35
2800 -32
3400 -32
4000 -32
4600 -32
5200 -34
5800 -34
6400 -39
7200 -39
7800 -39
throttle % is lo 5 hi 30
afr is 11.5
my setup is:
TO4E 60trim /T3 .63ar stage 3.
2.5"dp + exhaust
small pwr intercooler
stock fpr, fuel pump.
dsm450s, safc v2
Old Sep 20, 2003 | 12:15 AM
Default Re: (safe driver)
anyone else? im just trying to see what most people with h22 turbo are at with the afc hack
H22edAccord
Apr 27, 2004 09:08 AM
Bigjussin
Dec 30, 2003 02:53 PM
madhatch
Oct 22, 2002 01:00 AM
Quaalude
Jun 15, 2002 08:01 AM
