would this size slim fan fit stock civic radiator?
New User
10"slim fan. 11.2"(h) x 10.59"(w) x 2.05"(d)?
i usually hear people using 12" slim fans or b18bturbo's slim fans....12"(h) x 11.5"(w) x 2.5" (d).
the one i want to use is slighter smaller. what do u guys think?
Re: (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">the 12" fan is not a lot stronger than the 10", so with 10", you will be fine</TD></TR></TABLE>
how is a 10" stronger than a 12" if it puts out more cfms?
Re: (PrettyLude)
th 10" about 1000cfm to 1200cfm vs 1400cfm -1600cfm depending on the method
we usualyl dont sell alot of 10" fans but we have them as well they usually sold in pairs for people trying to put 2 in the stock locations works perfect that way
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Smaller should be fine. I just have my fan zip tied to my radiator [got it from viren].</TD></TR></TABLE>
i did the same thing
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">how is a 10" stronger than a 12" if it puts out more cfms?</TD></TR></TABLE>
I didn't say the 10" was stronger than a 12", read my post again. There is only a couple hundred difference in cfm between the 10" and the 12"
Re: (Unjockable)
Because it's not an FAL fan with an OEM style shroud that bolts into stock location. Also, I'm using mine as a pusher fan for clearance, and had to move the fan a little off center on the radiator. The zip ties have it on there solid, and it was cheap and easy.
