turbo cams!?
Old Mar 9, 2005 | 01:29 PM
ochsy03's Avatar
Default turbo cams!?
i searched "turbo cams" and only got 4 posts
i drive a 1999 honda civic si and i am buildin my motor right now..goin for 375+whp...b16a2..golden eagle sleeves, wiseco pistons 9:1 compression, eagle rods etc
what are some good turbo cams? MONEY IS NOT AN ISSUE
Old Mar 9, 2005 | 01:31 PM
quicksol95's Avatar
Default Re: turbo cams!? (ochsy03)
just keep your stock cams
or maybe gsr cams
Old Mar 9, 2005 | 01:33 PM
turboEGhatch's Avatar
Default Re: turbo cams!? (slow90hatch)
CTR/ITR cams. I picked up good power and spool over B16's.
Old Mar 9, 2005 | 02:59 PM
ochsy03's Avatar
Default Re: turbo cams!? (turboEGhatch)
keep my stock cams?? ahh i dont think so, cams can make a pretty big difference..yea i was lookin into itr cams...anyone have any experience with after market cams?(skunk2,blox,crower)
Old Mar 9, 2005 | 03:08 PM
Dunc's Avatar
BCICAN
I like skunk2's turbo cams....mainly because I am using them Check the two link in my signature for dyno graphs.
Old Mar 9, 2005 | 03:23 PM
Default Re: turbo cams!? (Dunc)
Skunk2 cams are both expensive and smaller than CTR/ITR cams.
Old Mar 9, 2005 | 03:30 PM
liam821's Avatar
25 Year Member
Id run GSR or ITR cams personally.
liam
Old Mar 9, 2005 | 03:32 PM
tony n.'s Avatar
Default Re: turbo cams!? (liam821)
gsr cams
Old Mar 9, 2005 | 03:41 PM
civicross's Avatar
Default Re: turbo cams!? (boosted2cam)
Crower makes a pretty nice turbo cam. I believe Rocket does too, but I don't know if it is out yet.
Old Mar 9, 2005 | 04:09 PM
ochsy03's Avatar
Default Re: turbo cams!? (civicross)
yea ive heard good things about gsr cams....also alot of people goin with the skunk 2 cams...anyone else?
acuracy r's Avatar
gsr cams
Old Mar 9, 2005 | 05:41 PM
liam821's Avatar
25 Year Member
Default Re: turbo cams!? (acuracy r)
I run JG race cams in my ZC. But only because you cant run vtec cams in a ZC heh....
liam
Old Mar 9, 2005 | 05:57 PM
celmar1's Avatar
Anyone have any good words on the JG 1001 Turbo cams?
Old Mar 9, 2005 | 06:00 PM
liam821's Avatar
25 Year Member
Default Re: turbo cams!? (celmar1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by celmar1 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any good words on the JG 1001 Turbo cams?</TD></TR></TABLE>
Those are the cams i run in my ZC. They are really awesome. Idles much better then my old crower cams.
The JG 1001 cams pulled strong and made power all the way until i let off on the dyno - could of made more too if i reved it higher.
liam
wantboost's Avatar
Who is Mr Robot?
liam, do you know if they make a similar cam for the vtec heads?
Old Mar 9, 2005 | 06:07 PM
celmar1's Avatar
Default Re: turbo cams!? (wantboost)
I think so, check out JGenginedynamics.com.
Old Mar 9, 2005 | 06:09 PM
liam821's Avatar
25 Year Member
They do make a vtec turbo cam, i believe its called the 300T. The grind is very close to a GSR grind from what i understand.
They have some dynos of the cams on their website: http://www.jgenginedynamics.com
liam
Old Mar 9, 2005 | 06:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">liam, do you know if they make a similar cam for the vtec heads?</TD></TR></TABLE>
Judging from the specs on their site the ZC turbo cams are near stock B16 came, but with less lift.
Old Mar 9, 2005 | 06:19 PM
XSIintegra's Avatar
&lt;~~going to be using GSR cams w/ gears.
Old Mar 9, 2005 | 06:44 PM
BluSiBoy's Avatar
Default Re: turbo cams!? (XSIintegra)
I have a friend who used GSR cams in his turbo B16A2, he was satisfied.
Old Mar 9, 2005 | 08:05 PM
TRC's Avatar
TRC
Default Re: turbo cams!? (BluSiBoy)
im runnin the skunk 2s. loving em. quite a bit of people are runnin with gsr cams here.
Old Mar 9, 2005 | 08:09 PM
PLAGUED_DB7's Avatar
Default Re: turbo cams!? (TRC)
blox cams.Too bad they dont make any for non-vtec
Old Mar 9, 2005 | 08:27 PM
BodyKits NW's Avatar
I ran Rocket Motorsports M20 Turbo Cam. I made power all the way past 9700 with those. They are a lil wilder than a CTR cam.
Rocket is making me a new cam that should give me even more power than before. I'll have dyno's of the new cams as soon as I get them. Hopefully not much longer.
383@10psi
Old Mar 9, 2005 | 09:19 PM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ochsy03 &raquo;</TD></TR><TR><TD CLASS="quote">i searched "turbo cams" and only got 4 posts
Just FYI, Your search for turbo cams returned 391 results.
You need to check the archives too, not just recent
Old Mar 9, 2005 | 10:04 PM
civicb18c's Avatar
jg1001's were the cams that chamois ran 11's with in houston from autologic tuned by st00pid
