84.5 mm bore and leaking issues??
Old Mar 8, 2005 | 10:58 AM
92HB_HB's Avatar
Default 84.5 mm bore and leaking issues??
is it just me or do 84.5mm (benson sleeved) GSR blocks have a better tendency to leak at the HG??
I"m currently running a Cometic and had some coolant/oil leaking issues.. I just retorqued the head and I believe the problem may have come back cuz I still see a little milky build up under the valvecover.. I cleaned it off b4 putting it back on and drove it for a couple days..
I just ordered a GE headgasket to replace it so hopefully it will solve the problem.. alos, any other suggestions to help make it get a good seal this time?? replacing HG's can get pretty expensive.. especially after spending a couple grand on a complete rebuild..
Old Mar 8, 2005 | 11:04 AM
turboEGhatch's Avatar
Default Re: 84.5 mm bore and leaking issues?? (92HB_HB)
I never had this problem with an 84.5 block, but we did on an 85.5 block. Less material between the cylinders means less for the head to clamp onto.
Old Mar 8, 2005 | 11:05 AM
trickeng's Avatar
while you have it appart this time make sure everything is square.
we use copper spray on cometic HP headgaskets unless the sleeves are higher than the block like RS Machine does. If the sleeves are decked flat with hte top of the block then only use the multi layer not the HP.
using a cometic hp gasket with raised sleeves will result in leakage every time.
Old Mar 8, 2005 | 11:07 AM
trickeng's Avatar
Default Re: 84.5 mm bore and leaking issues?? (trickeng)
he is getting a mix of coolant and oil, so between the cylinders does not seem to be the ploblem.
Old Mar 8, 2005 | 01:30 PM
92HB_HB's Avatar
i'm not sure if benson sleeves are stepped or not, but i dont think the problem lies b/w the cylnders..
i remember the other day trying to bleed the coolant by keeping the rad cap open while the car was running, and noticed that the coolant was bubbling over kinda like what u would see in a hot tub.. b4 the fans came on, it didn't do this and there wasn't any water drops dancing on the surface either.. so what gives??
xsi-t
Dec 29, 2006 03:43 AM
YashiMotors
Jun 26, 2006 11:47 AM
SIReg9
Oct 17, 2003 06:37 PM
Bucket
10
Jul 1, 2003 06:09 AM
integRated109
Sep 4, 2002 01:09 PM
