few questtns about knock sensors ECU´s and harnesses
1 Post
few questions about knock sensors ECU´s and harnesses
ok I already posted this in the technical forum but it seems that nobody knows an answer so I´ll try it here.
I´ve got a few questions about knock sensors. I know this was discussed a few times in the past but I couldn´t find something about my quesions.
I´m located in germany and I´ve got a EG6
1. question is....
Are the OBD0 OBD1 and OBD2 knock sensors the same??.. so can I put a OBD2 or OBD0 knock sensor to my EG6?
2. question...
I´ve heard that the european hondas do not come with a knock sensor. So will my EG6 engine harness and ECU support the knock sensor? Iwas told that I´ll need a japenese ECU.. is that correct??
3. question
I´m planing to buy a J&S safeguard so does it come with a knock sensor or do I have to use the OEM honda knock sensor?
Thanx for your help
Modified by hovic at 6:30 AM 3/9/2005
1. question is....
2. question...
3. question
Thanx for your help
Re: (hovic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hovic »</TD></TR><TR><TD CLASS="quote">
3. question
I´m planing to buy a J&S safeguard so does it come with a knock sensor or do I have to use the OEM honda knock sensor?</TD></TR></TABLE>
You have to supply your own sensor. I think it's meant to be used with the OEM sensor, but there may be others that would work.
3. question
1 Post
Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">knock sensors are specific to the bore of the motor.
OBD0 B16 = OBD1 B16 = OBD1 B18C = OBD2 B16 = OBD2 B18C
OBD2 D16Y8 != B*
H22 != B*</TD></TR></TABLE>
I´ve seen this on honda-tech so I´m wodering whats correct????
https://honda-tech.com/zerothread?id=1166995
OBD2 D16Y8 != B*
