GSR crank in my b16a. Benifits?
Re: GSR crank in my b16a. Benifits? (b16crxkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crxkid »</TD></TR><TR><TD CLASS="quote">just to add, is the LS crank and GSR crank the same?
no
no
Re: GSR crank in my b16a. Benifits? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny »</TD></TR><TR><TD CLASS="quote">You will need custom rods to keep the pistons from smacking into the head.
Sonny</TD></TR></TABLE>
You can, but it's cheaper/easier to just run custom pistons. If I were doing it I would probably just do custom pistons.
LS crank is an 89mm stroke, GSR crank is an 87.2mm stroke. Similar, but not exactly the same. B16 is 77.4mm for reference.
Re: GSR crank in my b16a. Benifits? (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch »</TD></TR><TR><TD CLASS="quote">
LS crank is an 89mm stroke, GSR crank is an 87.2mm stroke. Similar, but not exactly the same. B16 is 77.4mm for reference.</TD></TR></TABLE>
So an LS crank in GSR block would produce more power?? B/c i have an LS crank layin around...and i am building a B18c1 bottom end.
</TD></TR></TABLE> It might make a couple of hp here or there, but the main thing is that it creates more hp+tq at an early point in your powerband. Correct me if im wrong anybody.
Re: GSR crank in my b16a. Benifits? (drchulo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drchulo »</TD></TR><TR><TD CLASS="quote"> It might make a couple of hp here or there, but the main thing is that it creates more hp+tq at an early point in your powerband. Correct me if im wrong anybody.</TD></TR></TABLE>
It does, but the difference really is negligible. 0.071" difference in stroke between them, that's very insignificant. 37.10 CC's difference in displacement. To give you an idea, boring your GSR motor .5mm over is about a 22.2 CC inrease in CC's, but you don't hear anybody raving about the huge torque, or quicker spool that change gave them.
white4doorsi
03-15-2008 05:35 PM
