do you need to rewire anything on an obd1 motor with rc injectors?
searched but couldnt find my answer, do you need to rewire anything in order to run rc injectors on an obd1 motor? can you use the same injector clips?
Re: do you need to rewire anything on an obd1 motor with rc injectors? (B16Civic93)
If the RC's are saturated and your stock injectors are also saturated, then you're fine. If your RC's are low-impedance, and your stock injectors are saturated, then you'll need to run a resistor box. The injector clips of an OBD1 motor should plug and play with the RC's. But if you want to be sure, you can always buy RC injector clips which cost like $7-8 each.
RICE POLICE SIP
02-13-2010 10:01 AM
