REASEARCH HELP ON TURBOS>............
Old Mar 10, 2005 | 08:30 PM
acro_acura94's Avatar
Default REASEARCH HELP ON TURBOS>............
Alright..everytime i ask "what kind of turbo should i go with, and how should i build my engine to hold it"....i always get, "go do some research"....well i did, and i always get crap...can ne1 here help me that has a B18c vtec engine, that has a nice turbo setup, and the engine built?...also, could give me some help links to where i can get more knowledge on turbos, which one is right....My goal is to get 300whp...i know its all about tuning..but nething help full would be awesome..im a newbie to boost!...thanks
Old Mar 11, 2005 | 06:53 AM
EE_Chris's Avatar
Default Re: REASEARCH HELP ON TURBOS>............ (acro_acura94)
Well, from your 'research' thus far, what have you come up with? It can't all be crap and if you truly think it is crap, then at least use that as a starting point for further reading/searching.
You had to have pulled some idea of what turbo and what engine components need to be used to get to 300whp from your 'research'.
How about the SC61 to start with?
Old Mar 11, 2005 | 07:09 AM
TheShodan's Avatar
Moderator
I know this can get frusratting.
E-mail me at speedtrapp@wideopenwest.com Tell me what chassis and motor you're running and what kind of goals you're looking for in terms of power, drivability, and purpose. I guess I'm a sucker for a newbie.. But in the meantime, check out some other sites as well to try and even answer a couple of questions to get you started.
Old Mar 11, 2005 | 07:50 AM
Evanmb44's Avatar
well, with your goal of 300whp, you should be able to do that safely on a stock block with good tuning. why spend money building the engine when you could spend it on good fuel management to meet your goal.....dont overdo yourself in terms of what you want.
Old Mar 11, 2005 | 08:13 AM
kevino002's Avatar
Default Re: REASEARCH HELP ON TURBOS>............ (Evanmb44)
go to the book store and get Maximum Boost by Corky Bell, read that its a real good start. good luck.
Boricuanology
Jan 15, 2009 03:42 PM
scottysCRXsi
Aug 28, 2007 10:42 AM
jonbouy
May 12, 2004 07:13 AM
