car smoking questions
when i drive my car 1st 2nd 3rd and let off the gas there is a cloud of white smoke behind me and coming from under the hood. its hard to tell if the smoke is blue of white but i did a compression test and don't know if i tested it right but i got
150 in all 4. i only turned it over 4 times don't know if that matters
not oil leaks or burnt oil plz help
Re: car smoking questions (TURBODC4TEG)
it sounds like blowby. There is white smoke coming from the breather filter. Thats why youre seeing smoke from under the hood. The ringlands are toast.
at the jetties fishin'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG »</TD></TR><TR><TD CLASS="quote">when i drive my car 1st 2nd 3rd and let off the gas there is a cloud of white smoke behind me and coming from under the hood. its hard to tell if the smoke is blue of white but i did a compression test and don't know if i tested it right but i got
not oil leaks or burnt oil plz help</TD></TR></TABLE>
how old is the engine setup and the turbo setup? if it's a brand new buildup and brand new turbo kit then the smoke "could" simply be residues/coatings burning off during your first few heat cycles.
unless its like a billowy thick cloud or whatnot.
what does you oil smell/look like? have you smelled the smoke? antifreeze burning will have an almost chalky smell to it....oh and dont try to breathe in too terribly much since one of the products of antifreeze burning is phosgene gas
