FMU vs. Greddy blue box?
From: Murfreesboro, Tennessee, United States of America
My turbo kit is almost done i am running 7 psi on a dohc zc in a 91 crx now my eng. is obd 0 so to use the greddy bule box (that i have just lying around) i need to conevert my car to obd 1 or i could just use my fmu and buy a check vavle.
so what do yall think? and i dont have the $ for hondata oor orbadata
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Greddy blue box all day long over the FMU.
I'm running mine at 9 psi, stock pump/injectors, 2 degree timing retard.
I wouldn't recommend running that much boost, but around 7-8 psi on stock components is fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxzcracer »</TD></TR><TR><TD CLASS="quote">Thanks man but you still say that with the fact that i have to change to obd-1?</TD></TR></TABLE>
Well if you're going OBD-I, go Uberdata.
You'll already have the P28.
obd 1 > obd 0
might as well convert, drive-ability, throttle response, etc, etc, will go up compared to the older obd 0 setup
I always try to recommend the blue box to the 96-00 crowd just because it's so painfree compared to the other options for this year range.
but for joo, I say swap over to obd 1 and run uberdata
obd 1 > obd 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote"> Ive used both and the blue box gave me better performance, Ijust couldnt run a missing link w/blue box.
Ive now got uberdata "ostrich" and love it</TD></TR></TABLE>
why would i have to run a missing link with the greddy bule box?
screw going through the trouble of converting to obd1. Turbo edit is getting more and more better as time goes on. Before you convert to obd1 give Turbo edit a try. Definintly don't waste your time and money converting to obd1 just to run the blue box
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">screw going through the trouble of converting to obd1. Turbo edit is getting more and more better as time goes on. Before you convert to obd1 give Turbo edit a try. Definintly don't waste your time and money converting to obd1 just to run the blue box
hey i just thought of this why do i have to change to obd1 to use the bule box? do i have to or what? i dont now why i have it in my head that i would have to?
Evo-man@20psi
Mar 11, 2005 06:43 AM
blkeg2
Apr 25, 2004 03:52 PM
n*hance*ek
Dec 7, 2002 11:02 PM
