resistor box
Old Mar 8, 2005 | 06:03 PM
trbodelasol's Avatar
Default resistor box
bout 2 install sum 450 cc injectors....needed 2 kno wat resistor box 2 run and how 2 install
Old Mar 8, 2005 | 06:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: resistor box (trbodelasol)
https://honda-tech.com/zerothread?id=441107
https://honda-tech.com/zerothread?id=517274
Old Mar 8, 2005 | 06:10 PM
adseguy's Avatar
just get one off of here...search resistor box in the classifieds or something. Get new seals for your injectors....get the stock integra injectors seals at NAPA or something...then grind out the o-ring that goes on the Intake manifold.
Take off the fuel rail (if you can't figure this without with some help...don't turbo your car because you are a ******* dumbass) and unplug your stock injectors...take them out. Next test fit the grinded out orings and injectors...it should be snug...not too tight and not too loose. Then just put the fuel rail on the injectors and install the resitor box. I'm sure someone can provide a link on how to wire up the resitor box it's on HT if you SEARCH!
ILLuSiv3
Dec 1, 2011 10:19 AM
95dc2teg
Apr 15, 2007 08:32 PM
CelicaGT-S
14
Dec 2, 2005 03:32 PM
turbocivic96
Jan 29, 2004 05:09 PM
