Ignition timing difference in summer vs. winter
Old Mar 9, 2005 | 01:08 AM
mrx's Avatar
mrx
Default Ignition timing difference in summer vs. winter
Hallo,
i have a question to all the tuning gurus... when i make a ignition map on a dyno tune lets say in winter (5°C ambient i.e.) how much security retard do you apply to the map so that the chance of detonations is minimized in summer (30°C i.e.)
just to get an idea... i know it depents on the fuel so lets say 10:1 CR and 98 octane ROZ and aprox 14psi of boost.
Thanks
Malte.
Old Mar 9, 2005 | 01:39 AM
Andre's Avatar
Default Re: Ignition timing difference in summer vs. winter (mrx)
You don't retard the base map, you should use a "Intake air temperature vs. Ignition" correction table.
At 70C/160F i've 2° and at 80C/180F 3° retard.
If you retard your base ignition map by 3° you will loose some power all the time.
Old Mar 9, 2005 | 06:51 AM
platinum00's Avatar
Default Re: Ignition timing difference in summer vs. winter (Andre)
does hondata have a "Intake air temperature vs. Ignition" table
Old Mar 9, 2005 | 07:13 AM
93turbo16's Avatar
For some reason I don't think they have any correction factors. I would just go off some datalogs and make sure when you are going up in IATs you pull a few degrees out, this is best done on the dyno anyway.. It is almost like driving in the summer when you are on the dyno, atleast where I go because the temps are very warm inside.
VegasInvasion
Engine Management and Tuning
19
Sep 10, 2023 04:11 AM
D21X
34
Feb 3, 2015 03:28 PM
1SlowSi
Nov 6, 2007 08:20 PM
srg
Aug 18, 2006 09:50 AM
