lowering compression, on high compression map, lean, rich?
Old Mar 10, 2005 | 06:55 PM
NotPhilTran's Avatar
Default lowering compression, on high compression map, lean, rich?
hey guys, rebuilding my engine as we speak, b16 10.2:1 compression
im putting in 9:1 arias pistons, my car is tuned with hondata on previous stock compression. 450cc injectors with walbro255.
now my question is i want to take it straight ot the dyno, is my compression going to lean out my engine or richen it up too much taht i cant drive it to the dyno to tune?
where should my tuner start to go with my stock maps? high igniton? lower? retard more timing? fuel more or less on lower compression?
i just dont want to flood my rings on the way to the dyno. thanks guys.
phil.
Old Mar 10, 2005 | 07:00 PM
turboEGhatch's Avatar
Default Re: lowering compression, on high compression map, lean, rich? (NotPhilTran)
Your car should run a bit richer at all settings, nothing ground breaking or anything that will make the car undriveable. Too much emphasis is put on compression. The 9:1 setup will take a good amount more timing, so keep that in mind. I'd start from the 10.2:1 map and add some timing in. Boosted Hybrid posted on his board that going from 10:1 to 9:1 on a GSR took 5-6 degrees more timing, so keep that in mind.
Old Mar 11, 2005 | 09:17 AM
Default Re: lowering compression, on high compression map, lean, rich? (turboEGhatch)
why thank you.
boost is my friend.
Old Mar 17, 2005 | 05:40 AM
any other opinons?
the_yblegal
Engine Management and Tuning
Jun 2, 2014 04:50 PM
gc8dc95
Feb 16, 2009 04:29 PM
freeshot350
Aug 13, 2007 08:09 PM
AL ASPIRATED
Aug 22, 2003 04:52 PM
RICHJ
Feb 18, 2003 05:48 PM
