Smaller gap spark plug
Old Mar 10, 2005 | 06:28 PM
kaoss_11's Avatar
B A N N E D
Default Smaller gap spark plug
Where can i find plugs with a .22 gap? I have tried searching already.
Old Mar 10, 2005 | 06:30 PM
93turbo16's Avatar
just curious.. but why do you want it gapped that low?
Old Mar 10, 2005 | 06:37 PM
Jefnes's Avatar
Default Re: Smaller gap spark plug (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">Where can i find plugs with a .22 gap? I have tried searching already.</TD></TR></TABLE>
What????
you don't buy plugs gapped to .022"
you gap them yourself....
Jeffrey Atwood
Old Mar 10, 2005 | 06:41 PM
kaoss_11's Avatar
B A N N E D
Turbo keeps fouling them as soon as i boost my car bogs thats the only thing left i think that could be wrong. I am new to this turbo thing and how would i go about gapping them
Old Mar 10, 2005 | 07:10 PM
vaporboy12's Avatar
Default Re: (kaoss_11)
.22 is way to small
Old Mar 10, 2005 | 07:12 PM
SOHC_MShue's Avatar
you have to gap them yourself....
How rich are you running?
Old Mar 10, 2005 | 07:17 PM
kaoss_11's Avatar
B A N N E D
All i can say is very. The car runs perfect but as soon as i boost it falls flat on its face
Old Mar 10, 2005 | 07:21 PM
93turbo16's Avatar
what is your setup and what is your management?
Old Mar 10, 2005 | 07:23 PM
SOHC_MShue's Avatar
I thought you said that guy tuned your car in your kill stories thread. Obviously he didn't do a good job?
Old Mar 10, 2005 | 07:25 PM
beepy's Avatar
Default Re: (SOHC_MShue)
0.022 is too small. The NGK BKR7ES-11 is pre-gapped at 0.030", which is good for most turbo cars. They are usually a special-order part, though.
Old Mar 10, 2005 | 07:26 PM
oxSLEEPERxo's Avatar
lol, go to autozone and buy their gapping coin, it's $1.
Old Mar 11, 2005 | 06:55 AM
kaoss_11's Avatar
B A N N E D
It was tuned and then 2 weeks later this is happening. Why would i lie about something? Obviously as you can see i am asking for help.
I am sure that putting my msd on would help out some. The reason why i asked for a 22 gap is because the guy that tuned my car said to do it
Old Mar 11, 2005 | 06:57 AM
kaoss_11's Avatar
B A N N E D
I actually already ordered some bkr7e the other day and i know the gap is 30. So are you guys saying that should be more than enough for a turbo car
Old Mar 11, 2005 | 06:59 AM
beepy's Avatar
Did you say you put an MSD on the car?
Take it off. I had the same problems when using a DIS-2. Capacitive discharge is not good for turbo.
Old Mar 11, 2005 | 07:03 AM
EJ1 wilcox's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">0.022 is too small. The NGK BKR7ES-11 is pre-gapped at 0.030", which is good for most turbo cars. They are usually a special-order part, though.</TD></TR></TABLE>
You can buy them pre-gapped?
I had to gap my plugs myself... I don't remember which ones I bought though, they are just one step colder than stock, I gapped them to 0.030" and it works great!
Why would you special order them pre-gapped if you can just buy regular plugs and gap them yourself?
Old Mar 11, 2005 | 07:39 AM
kaoss_11's Avatar
B A N N E D
I have msd i just have not put it on yet. I was also reading a thread where someone ordered .30 plugs and the car was stilling running horrible. Adter that he gapped the plugs to .20 and he said the car ran like a champ
Modified by kaoss_11 at 8:49 AM 3/11/2005
Old Mar 11, 2005 | 08:59 AM
beepy's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Why would you special order them pre-gapped if you can just buy regular plugs and gap them yourself?</TD></TR></TABLE>
Because the ungapped plugs are at about 0.044", and takign them down to 0.030" or less makes it impossible to get the electrodes parallel.
Plus nobody sells proper gapping pliars anymore. Couldn't even get them from Snap-On! Basically you have to hammer the gap down then use the $1 ring to get it back, but that again makes it impossible to get the electrodes parallel.
Old Mar 11, 2005 | 09:25 AM
EJ1 wilcox's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Because the ungapped plugs are at about 0.044", and takign them down to 0.030" or less makes it impossible to get the electrodes parallel.
Plus nobody sells proper gapping pliars anymore. Couldn't even get them from Snap-On! Basically you have to hammer the gap down then use the $1 ring to get it back, but that again makes it impossible to get the electrodes parallel. </TD></TR></TABLE>
Hmmmm.... that does make sense... and it does seem like you have to bend the electrode quite a ways to get it down to 0.030"... does it affect performance if the electrodes are not parallel?
Old Mar 11, 2005 | 09:35 AM
Hyaboosta's Avatar
yeah I wouldn't gap them to .22 thats gonna be way too hot. If you have them gapped to .30 and still having this problem then it's a fuel system issue or tunning. what is your emgine management?
Old Mar 11, 2005 | 10:25 AM
kaoss_11's Avatar
B A N N E D
hondata
Old Mar 11, 2005 | 10:29 AM
kaoss_11's Avatar
B A N N E D
My spark plugs look like this if this helps any.
Modified by kaoss_11 at 12:48 PM 3/11/2005
Old Mar 11, 2005 | 10:32 AM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">does it affect performance if the electrodes are not parallel?</TD></TR></TABLE>
I am using the non-parallel electrodes, because, like I said before, I have a hard time getting parts stores to order me the ES-11's, and haven't found a place online that sells them by part number, only application.
Anyway, what I have noticed it that the electrodes wear very quickly on the tip. My guess is that the spark is jumping from the corner of the electrode, and slightly melting it. So after 3000 miles or so I need to recheck my gap to make sure it hasn't grown. I also tried using the V-Power version of the plug, and the V-groove was almost completely worn away after 5000 miles or so. In any case I end up changing plugs almost as often as oil.
Old Mar 11, 2005 | 11:25 AM
sharkcohen's Avatar
Default Re: (beepy)
BKR7ES-11 (2387) is gapped at .044: 1.1 mm, hence the -11 in the part number.
BCPR7ES (3330) is almost identical to BKR7ES-11. It is 3 mm longer from seat to terminal (which doesn't affect anything), and comes gapped at .032.
I think you are thinking of BKR7ES, which I can't seem to find anywhere, either. It may be a discontinued plug.
Old Mar 11, 2005 | 11:49 AM
kaoss_11's Avatar
B A N N E D
so trhe bkr7e is fine then correct
Old Mar 11, 2005 | 12:10 PM
SL0WEGG's Avatar
i had my plugs gapped at .028 and it worked fine.
