DPI to MPFi help JRSC
Old Mar 10, 2005 | 07:01 PM
93supercoupe's Avatar
Default DPI to MPFi help JRSC
So i did the DPI to MPI conversion and then converted to OBD1 and am running untuned uberdata w/ the charger.
My questions are:
The to white wired that are the same on the Distro plug, what happens when they are crossed.The reason im asking is becuase my car feels like its hitting rev and 3500-4500.I know more than likely its the crank angle sensor, so i swithed those two wires and came out with the same result.
How do u check CEL's on the conversion harness.I have the check engine wire and a PCM wire(unused) and i was wondering if u ground them together or ground the CEL wire or what
Old Mar 10, 2005 | 07:50 PM
Default Re: DPI to MPFi help JRSC (93supercoupe)
Its missing also, like aplug isnt firing, or maybe an injector.Its late, it runs, im happy
Old Mar 10, 2005 | 08:24 PM
what other wires besides the 4 injector wires run to the resistor box?
Old Mar 11, 2005 | 02:10 AM
6a.m. bump
BigChance
May 29, 2011 10:29 AM
oneslowstd
Nov 26, 2006 12:16 PM
93supercoupe
Mar 11, 2005 10:43 AM
spun Vtec
10
May 12, 2003 06:21 PM
SohcVtecCrix
Aug 8, 2002 07:22 PM
