This is probably a stupid question...Internal/external wastegates
Old Apr 12, 2007 | 01:15 PM
blwnengnls's Avatar
Default This is probably a stupid question...Internal/external wastegates
I am switching my car from a greddy setup with a 18g to a garrett t3/t4...When I bought my new turbo it is set up for an internal wastegate. I am starting to figure out that I am going to have a hard time fitting the turbo on the car with the internal wastegate, but will my turbo work with a external wastegate or do I need a new housing on the turbo without the hole for the wastegate...sorry if this is a stupid question but I need to figure it out! thanks
Old Apr 12, 2007 | 01:51 PM
slowrx's Avatar
You should be able to take the actuator and arm off, and then just weld the flapper shut and be fine.
Old Apr 12, 2007 | 06:40 PM
boostedblkef's Avatar
Default Re: (slowrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowrx &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to take the actuator and arm off, and then just weld the flapper shut and be fine.</TD></TR></TABLE>
UK_prelude VTEC
Jan 20, 2006 08:19 AM
brnzbuddha
Feb 4, 2005 07:46 AM
JustinL
Oct 9, 2004 04:34 PM
Dasani
Apr 1, 2004 07:31 AM
mrsurfermike2001
May 15, 2003 10:01 AM
