will a gsr .bin work with an ls vtec? or what shuold i use as a base?
iv got a chipped ecu and i cant get it to run good. what are some of you using as a rough basemap? i dont have the turbo on yet. i wanted to get my car running good before i boost it. everything is ready to do though. the 450cc injectors are in as well as a tapped oil pan that is capped. so i just need to scale the maps for 450cc injectors and then take it out and break in the new motor.
so, why doesnt the gsr map work good? id idles like crap, surges, sometime stalls out. i mean i dont have a gsr head, but i made the secondaries come on before the primaries so they will never turn on. other than that in theory it should work great right? my setup is
b18b bottom
b16 head
gsr pistons
itr cams
450cc injectors
running NA for the time being.
if someone has a map that they know works good please help me out. im getting really frusterated.
b18b bottom
b16 head
gsr pistons
itr cams
450cc injectors
Re: will a gsr .bin work with an ls vtec? or what shuold i use as a base? (boosted k20)
im working on it. what is a good base to start with? why doesnt the gsr work?
Re: (Sketch_hs)
why will the gsr work only to get me to the tuner? what i built is almost identical to a gsr. should the gsr map work great? or even an itr map?
Re: (melovesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melovesboost »</TD></TR><TR><TD CLASS="quote">GSR, SI, Type R.. if you use the GSR be sure to disable the IAB (secondary butterflies)</TD></TR></TABLE>
????? u dont know what ur talking about. u dont need to disable anything.
a basemap is meant to start the car up and for u to start tuning it good. some people will create great basemaps that will get the car running pretty good, some people make shitty basemaps.
tune the car!
tune the car!
well i just re read his setup. he is using a GSR map already but he says he is running a b16 head. He is playing with the secondary controls when he doesnt even have the right intake manifold on..
Also check for some CEL
Re: (melovesboost)
the only way to disable the secondary controls is to make the secondaries lower than the primaries so they never come on. i dont think a b16 map will work for an gsr? 1.6l vs. 1.8l. i just want to have a good idle, and cold start. the rest of the fuel maps are easy to tune. thanks
Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">????? u dont know what ur talking about. u dont need to disable anything.
tune the car!</TD></TR></TABLE>
HE IS GOING TO TUNE THE CAR!! He just needs a good basemap to start w/.
Enough w/ the tuning, he knows that, if u cant help, SHUT UP!!
Re: (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">
Enough w/ the tuning, he knows that, if u cant help, SHUT UP!!</TD></TR></TABLE>
thanks, ya i know what im doing all over the other places of the map. its just getting it going. i cant figure it out. i just want to getting it idling smooth. sometimes these suck to **** around it and if i dont start with a good base its a waste of my time. maybe there is something else messed up. i dont have a code, has anyone used a gsr map with a pretty much "stock" ls vtec?
Re: (93supercoupe)
if ur burning a chip then start making changes!!!! its not that hard. if its not running good start adding/subtracting fuel till its good enough to drive to get tuned! u guys want every thing spoon fed to u.
and if u want some basemaps, go to xenocrons website for basemaps http://www.xenocron.com/bins/
and enough with the disabling of the secondaries. U DONT NEED TO DISABLE ANYTHING!!!!!!
ive done over 60-80 ecu's and i have used some of the same basemaps to get GSR's, B16's, LS/VTECS to run decent enough to get tuned. LS/VTEC with GSR or B16 head is not gonna make a world of a difference to get the car running.
go to that above website to get some basemaps
Re: (the.hamburglar)
do u have any CEL? did u install a resistor box is u r run n DSM or low impedance injectors?
if i were u i would install the stock injectors in the car and run the stock ecu just so u can elimnate the possibility of a "bad basemap". if the car runs fine with that, then put in the 450cc and start adding/taking away fuel from a 450cc basemap.
Re: (boosted k20)
i think ill just put the turbo and and use the map i used all summer. i really wanted to tune na just for fun but this is getting rediculous. i know my turbo map works good. thanks for the help and suggestions though
