how about this for an idea
Old Apr 9, 2007 | 02:28 PM
civicboy96's Avatar
Default how about this for an idea
i own a 99 si and have been battling the turbo or supercharger war. either way i would like to make 300 hp safely on only forged rods and pistons. i plan on running hondata s300 for em. for the super charger- would it be a bad idea to run a jackson racing supercharger at the 6-8 psi, but add pistons with the cp ratio of the ctr or leave the stock b16a2 cp @ 10.5-1. i was wondering if high compression and low boost is better than low compression and high boost-was trying to get away from having to sleeve the block and read that cylinders dont start to move around until about 15 psi. I have tons of questions on this topic but this would be a good place to start. thanks guys!
Old Apr 9, 2007 | 02:36 PM
BoostedEG6's Avatar
Default Re: how about this for an idea (civicboy96)
you are going to need more than 8psi from a SC to mke 300whp
your going to be better off going turbo
Old Apr 9, 2007 | 02:47 PM
slowr6's Avatar
turbo all the way
Old Apr 9, 2007 | 02:53 PM
doood's Avatar
been there done that
Default Re: how about this for an idea (BoostedEG6)
stock internals can handle 300whp fine if the engine is still healthy and your tune is up to par
Old Apr 9, 2007 | 03:01 PM
civicboy96's Avatar
Default Re: how about this for an idea (doood)
the engine has just under 29,000 original miles and the comperession check comes out at 190 across the board, pedal fully pressed-turned over 5 times. i have heard that if i add any thing to the rotating mass, (crank-rods-pistons) other than stock, it will need to be rebalanced, is this ture? the turbo i was thing about was a precision sc-61 or sc-34. what do you guys think. ive been searching for ever and am trying to figure most things out before i go shopping. all said and done, what is a reasable time i can look at for the dyno and tune, so i can budget some money. thanks in advance!
Old Apr 9, 2007 | 07:36 PM
slowr6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">the engine has just under 29,000 original miles and the comperession check comes out at 190 across the board, pedal fully pressed-turned over 5 times. i have heard that if i add any thing to the rotating mass, (crank-rods-pistons) other than stock, it will need to be rebalanced, is this ture? the turbo i was thing about was a precision sc-61 or sc-34. what do you guys think. ive been searching for ever and am trying to figure most things out before i go shopping. all said and done, what is a reasable time i can look at for the dyno and tune, so i can budget some money. thanks in advance!</TD></TR></TABLE>
sc61
Old Apr 9, 2007 | 07:56 PM
Runnerdown's Avatar
Default Re: how about this for an idea (slowr6)
300 whp with a wide powerband. I'd go with a garrett t3/t04e 50 trim .48 a/r or a gt28RS t3 .63a/r.
Datechmaster
Nov 6, 2014 11:57 AM
93delslow315
Nov 30, 2010 03:33 PM
Prelude91siT
Jan 11, 2008 04:26 AM
Dasani
Jul 7, 2006 05:13 AM
