ek wont rev past 4500rpm when i floor it?????
just put my t3 turbo on and it will not rev past 4500 rpm when i floor it, but it will when i accelerate slowly. anybody know why???? thanks
Re: ek wont rev past 4500rpm when i floor it????? (Hondaruss)
it does not missfire. it fells like it hits rev limit, only when i floor it
i have a stock gsr motor, stock fuel and ignition.
car ran fine when it did not have turbo.
Re: ek wont rev past 4500rpm when i floor it????? (lsrcrvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsrcrvtec »</TD></TR><TR><TD CLASS="quote">it does not missfire. it fells like it hits rev limit, only when i floor it
is your car even tuned? or ecu even chipped? mostly likey your map sensor is seeing boost, not allowing u to rev past a certain RPM, since your doing it slow its not reading boost, and once u smash and build boost it reads it when its not supposed to, get the ecu chipped and tuned
Re: ek wont rev past 4500rpm when i floor it????? (m3 boostin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3 boostin »</TD></TR><TR><TD CLASS="quote">turbo may not be getting enough air, do u have something over it or u running open turbo? </TD></TR></TABLE>
no.
no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsrcrvtec »</TD></TR><TR><TD CLASS="quote">just put my t3 turbo on and it will not rev past 4500 rpm when i floor it, but it will when i accelerate slowly. anybody know why???? thanks</TD></TR></TABLE>
sounds like the ecu is cutting the engine out because of not enough fuel. i had the same problem when my ebc was sticking and causing the boost pressure to go too high; the engine would cut out like i was hitting the rev limiter. why are you even trying to rev it up with a stock fuel system? get some bigger injectors, a chipped ecu, and get it tuned.
omg my car is doing the same thing but its on a h22 on a civic i got 550 on it i got it street tuned but its still doing that im thinking i need to get it retuned it pulls hard at 5k rpm and then it feels like its hesitating dnt knw why
Re: (h22silvia)
Well...this probably is not the best way to go about a turbo project. There are multiple problems here and not just one fix. We will start with stock fuel stock ign(as far as timing advance/retard)...that needs to be changed. I am also assuming that you are unsure of how much boost you are running?
As for your early "rev-limit"...not getting too technical... the stock code in the ECU has a voltage range that it can see from the map sensor. A MAP (Manifold Absolute Pressure) sensor measures manifold pressure. negative pressure being vacuum and positive pressure being boost.. Even though the stock 1.7 bar map sensor can handle up to 10-11 psi..the stock ECU code sees any positive pressure as "out of range" and may even substitute TPS readings for MAP readings. Either way positive pressure on the stock ECU isnt going to work out with great results. What ROM editing programs that have boost support do is not only extend the exceptable voltage range from the MAP sensor but also extend the fuel and ign maps with fuel and ign values to represent these voltages.
If you feel your car is worth it, contact me and we can work out getting your car running reliably as well as making some pretty decent power.
thewrai6th
08-14-2007 05:44 PM
DamonBoost
10-28-2001 01:54 AM
