where are your guages??? Pics please
hey guys, should be t/c my 98 gs-r soon and just wanna see where you guys have your guages installed within your car.
Re: where are your guages??? Pics please (phish4709)
i have crx and i went with jdm double din block off and mounted boost and egt on that and then took out climate control and fitted carbon fiber block off there and mounted my oil pressure guage there...i think if you can do it use block off plates cause i dont care for pillar mounts,heres a pic http://www.we-todd-did-racing....ew9lt
I got the Autometer cluster bezel, which surprisingly fits well, and I also put two more in the holes where the cruise and rheostat switch go. Those two holes had to be reamed out because the guages wouldn't fit. Not sure if you're willing to do that, because you can't reverse this process. If you do decide to do it, just leave the rheostat plugged in tucked inside the dash, or your dash lights won't work. I leave myine on full brightness anyways, so it makes no difference. I guess if you have cruise, you might wanna just relocat the button to the plastic cover that sits under your steering column. That's the best I could think of. I don't have cruise, so I didn't have that problem.
