BOV setup HELP!!!! Vacuum source???
Old Apr 8, 2007 | 12:57 PM
dumas07's Avatar
Default BOV setup HELP!!!! Vacuum source???
Hey i am strapping together my fmic setup and i was wondering for a 99 integra ls, what vacumm source should i attach the BOV to? Intake Manifold or what??? and be specific if you can help im noob!!
thanks
Old Apr 8, 2007 | 01:01 PM
a1320addict's Avatar
Default Re: BOV setup HELP!!!! Vacuum source??? (dumas07)
What type of valve are you using?
Best bet is to tap a T into the brake booster line (in between the manifold and check valve), and run a line to another T, then one to your wastegate, one to your bov.
Provides a strong supply of vacuum.
Old Apr 8, 2007 | 01:05 PM
BEST1TUNING.COM's Avatar
Modified by BEST1TUNING.COM at 2:24 PM 4/8/2007
Old Apr 8, 2007 | 02:04 PM
inspyral's Avatar
I run all my vac lines from a vacuum manifold tee'd into the brake booster line.
Old Apr 8, 2007 | 03:40 PM
crvtkllr's Avatar
Default Re: (inspyral)
Provides a strong supply of vacuum.[/QUOTE]
does this count for the b16 too????
Old Apr 9, 2007 | 12:50 AM
taggart_lumpy's Avatar
just purchase a vacuum block from ge, full race, ebay, ect.......
Old Apr 9, 2007 | 01:50 AM
almostboostedgsr's Avatar
Default Re: (taggart_lumpy)
do you even did a vaccum line from the bov.
I thought there was not a reason too.
Old Apr 9, 2007 | 01:58 AM
BoostedEG6's Avatar
Default Re: (crvtkllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtkllr &raquo;</TD></TR><TR><TD CLASS="quote">does this count for the b16 too???? </TD></TR></TABLE>
Thats for any motor..... It is best to run a VAC manifold T'ed into the Brake booster like said above
Old Apr 9, 2007 | 02:00 AM
Default Re: (BoostedEG6)
do you need a vac line for the bov ?
Old Apr 9, 2007 | 02:04 AM
BoostedEG6's Avatar
Default Re: (almostboostedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">do you need a vac line for the bov ?</TD></TR></TABLE>
yes
inthad
Oct 2, 2007 05:37 PM
playa6188
Feb 13, 2006 07:13 PM
HondaCutter
Sep 26, 2002 04:20 PM
Integra_Boi
Aug 13, 2002 02:10 AM
