H23 Turbo setup? can any1 help me?
Can sum1 plz help me on putting a turbo in my 92 Lude SR.
Im in the process of doing it right now, but im running into a lot of problems.
I bolted on the exhaust manifold, but the turbo won't fit now because there isnt enough room to put the intercooler piping on the end of the turbo. it is hitting the block.
Is there a way to turn the turbo around or sumthin?
Re: H23 Turbo setup? can any1 help me? (j-yous)
u can adjust ur cold side..there are pry like 8 bolts going all the way around the turbo..just loosen them up and adjust the cold side to where you need it.
Re: H23 Turbo setup? can any1 help me? (ericstambaugh07)
I did try that, but the motor mount was in the way, I have to run that side to my intercooler right?
Also, the blowoff valve, what does that hook up to. wat do i plug on those two valves sticking out of it.
