fuel pump wire?
Old Apr 10, 2007 | 01:30 PM
turbo boost's Avatar
Default fuel pump wire?
ive got a ef with a walbro 255hp...do u guys rewire them with bigger wire?....i used the bigger wire the comes with the install kit....but what about the wires that go from the tank to the ecu??..i noticed that my wires get warm..is this normal?...do u need to put a lil bigger fuse in?
thanks
Old Apr 11, 2007 | 09:31 AM
mahatma's Avatar
Default Re: fuel pump wire? (snowbunny)
don't use a bigger fuse.
i've had your same chassis/pump for well over a year with no negative side effects.
Old Apr 11, 2007 | 05:07 PM
Default Re: fuel pump wire? (mahatma)
ok thanks
Old Apr 11, 2007 | 05:16 PM
Snafubmx234's Avatar
Get yourself a relay. Run a thick gauge wire (8 possibly?) from the battery to your fuel pump through the relay. Use the signal from your ECU to power the relay.
Your fuel pump will love you
Old Apr 11, 2007 | 05:48 PM
Default Re: (Snafubmx234)
ok..what size relay??
Old Apr 11, 2007 | 07:44 PM
nitroice40's Avatar
Default Re: (snowbunny)
standard 30a
Old Apr 12, 2007 | 12:05 AM
akira712's Avatar
8 gauge wtf
30 amp bosch relay with 12 gauge will be plenty
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snafubmx234 &raquo;</TD></TR><TR><TD CLASS="quote">Get yourself a relay. Run a thick gauge wire (8 possibly?) from the battery to your fuel pump through the relay. Use the signal from your ECU to power the relay.
Your fuel pump will love you </TD></TR></TABLE>
Old Apr 12, 2007 | 11:54 AM
Default Re: (akira712)
ok kool..i got some 10 gauge laying around and ill pick up a 30A relay
ESP.net
Mar 13, 2014 08:44 AM
pleej
Apr 8, 2011 11:06 AM
crxfreak1117
Aug 15, 2009 06:09 AM
servion
Jun 3, 2004 07:54 AM
JDubya
Audio / Security / Video
Jun 9, 2003 01:16 PM
