Question about compression ratios between gsr and b16 heads in turbo built block
ok i ran myself into a wall trying to figure out what my compression ratio would be in my block motor
my block has JE pistons they are 8:2:1
im running a GSR head (figure another .2 points)
so that would be 8:4:1
with a thinner gasket that will raise compression a few more points? or would that be a bad idea?
could i expect another .2 points from a thinner gasket? making it 8:6:1?
i searched and used a compression calculator but it didnt help much as im not 100% on the dome cc and all that of my piston
7rrivera7
01-25-2010 06:45 PM
Nextelbuddy
10
10-08-2003 05:47 PM
