easiest way to calculate turbine inlet pressure???
i am trying to choose a proper A/R ratio for my turbo setup - How can I determine the turbine inlet pressure, is there a mathematical formula? What values am I measuring?
Re: easiest way to calculate turbine inlet pressure??? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Not really.</TD></TR></TABLE>
There is a section in the Maximum Boost book about the importance of turbine inlet pressure, and Corky says pretty much the same thing, you have to measure it. He states that high pressure equals faster spool and lower top end, while lower pressure is the opposite. I know that seems obvious to some folks here, but Corky's summation pretty much stated that at that point, you're back to trial and error to get it just right.
Craig
Craig
Re: easiest way to calculate turbine inlet pressure??? (civickid03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickid03 »</TD></TR><TR><TD CLASS="quote">is there any way to estimate?</TD></TR></TABLE>
there are way too many variables that go into it to estimate.
