e85 or c16?
Old Apr 8, 2007 | 08:34 PM
NAEH2NA's Avatar
Default e85 or c16?
ok so im building a 2.0 on a 4094 full race top mount 9:1 compression manley rods ....
trying to make 7-the 750 range now my question is e85 or c16 will 1600s be enough on e85 or will i have to run a 8 injector setup ?and can i use a stock timing map with e85 or do i have to make a custom one ? will i make more power on lower boost with the e85 than c16 ? is there any disadvantages for either over the other one ? hope to hear some input thanks
vince
Old Apr 8, 2007 | 08:37 PM
igo4bmx's Avatar
uhh
e85 is a bit cheaper than c16
not many people have tried tomake alot of power on e85
e85 will need different tuning compared to regular pump gas.
Old Apr 8, 2007 | 08:43 PM
Boosted B6teen's Avatar
Default Re: (igo4bmx)
If you run E85 you will need ginomous injectors to get 700+whp
Old Apr 8, 2007 | 08:46 PM
bigbadboy's Avatar
tuning will be pretty much the same as pump except for the fast that you'll need more of it than regular gas. but e85 is def. better. not sure how big your injectors need to be to run high hp but 1000's will net you a little over 500. so i think you'll be fine with 1600's.
Old Apr 8, 2007 | 09:09 PM
NAEH2NA's Avatar
Default Re: (bigbadboy)
not really concerened in price and isnt e85 a differnt mix in the winter than in the summer ? lets here some more input
Old Apr 8, 2007 | 09:23 PM
bigbadboy's Avatar
bump for more info for you:
https://honda-tech.com/zerothread?id=1701028
https://honda-tech.com/zerothread?id=1812349
https://honda-tech.com/zerothread?id=1810096
Old Apr 8, 2007 | 09:52 PM
tony413's Avatar
havent seen any for sale yet but try looking for 2000cc injectors and get an aeromotive eliminator fuel pump or the drag pump. also you gotta remember the E85 is alcohal not gasoline so of course tuning is different. when you compare the two to each other at same boost levels you will see higher with alcohal because as it burns it has a cooling effect also theres no detenation. you need to do alot of searching theres no clear one choice answer unless your going by which one you can buy daily and thats E85
Old Apr 8, 2007 | 09:53 PM
nexxxt's Avatar
Default Re: e85 or c16? (NAEH2NA)
"could you use the the stock timing map"
-hmmmmmm
Old Apr 8, 2007 | 09:54 PM
CivicVX94's Avatar
Default Re: e85 or c16? (nexxxt)
idk where you live, but i know that the nearest gas station to get e85 is well over an hour away
that alone made my decision...
Old Apr 8, 2007 | 10:03 PM
tony413's Avatar
im about 20-30 miles from an airforce base an they have E85 in that area so i do what i gotta do . and for nexxxt you have to modify the fuel map for both fuels so dont worry about it just get a tunable ECU without one theres no point in going higher than 230hp
Old Apr 9, 2007 | 06:06 AM
tony1's Avatar
Default Re: (tony413)
We've done 719whp on E85 with 1600's and a base of 55psi. Though i'd recommend C16 at that power level.
Old Apr 9, 2007 | 06:38 AM
CivicVX94's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">We've done 719whp on E85 with 1600's and a base of 55psi. Though i'd recommend C16 at that power level.</TD></TR></TABLE>
wow 719?! that's crazy...
how does something like that idle w/ 1600cc injectors and e85?
Old Apr 9, 2007 | 07:31 AM
nexxxt's Avatar
Default Re: (tony1)
i know. i was pointing out that the creator of the thread was asking if he could us eht stock timing map on a 700+whp car.. didnt make too much sence, if hes asking what fuel to use for that hp, he should know the car needs a new fuel and timing map for every little thing he does...
Old Apr 9, 2007 | 10:54 PM
NAEH2NA's Avatar
Default Re: (nexxxt)
im not saying to use a stock timing but could i even use the base and modify it like a hondata map ..? both are available to me 15 minutes from my house ..probally just going to run the c16 thanks guys
Old Apr 9, 2007 | 11:05 PM
efeezie's Avatar
Tony1- what IDC were you at that power level?
Old Apr 10, 2007 | 08:08 AM
servion's Avatar
Default Re: (tony1)
Very nice. Do you know if it was a winter blend? I assume plugs looked good? What heat range did the motor like best?
delfast
Feb 26, 2010 03:21 PM
Jdc5
Nov 20, 2008 12:12 AM
Dat1BVtecN
Oct 16, 2008 07:57 PM
projekt-sol
Feb 4, 2008 06:16 AM
purpleh22
Jul 11, 2006 08:31 PM
