Help Needed with Fuel Pressure Regulator, Fuel Pump & Fuel injector choices?
Location: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
I have a LS block and CRV head with t3/t4 turbo setup that I'm putting together and with all the choices with Fuel Pressure Regulator, Fuel Pump & Fuel injectors, what choices do you guys recommend for my setup? Thanks in advance!
Re: Help Needed with Fuel Pressure Regulator, Fuel Pump & Fuel injector choices? (01PYTypeR#1140)
Simple.Aeromotive fpr,Walbro 225 fuel pump,750cc injectors.That will handle anything you going to drive on the street.
Mr. Badwrench
Re: Help Needed with Fuel Pressure Regulator, Fuel Pump & Fuel injector choices? (NJIN BUILDR)
whats your hp goal? up tp 400 whp, stock reg, rail, filter. 550-650-750 injectors. agree with the walbro
Thank You! Can I get a couple people to agree or post other options that would serve me better before I spend my hard earned money. Thanks guys you rock!
Re: Help Needed with Fuel Pressure Regulator, Fuel Pump & Fuel injector choices? (boostedcivicsir)
I want to be at about 300 whp when all said and done.
Mr. Badwrench
not to argue with njin, but we have tuned cars close to 400 wheel, with a stock reg. a stock rail is proven ok to 400 +- injectors, precision, rc, they are both good. i used precision in the turbo t i had, and using rc's in the civic i have now.
