Painting A Turbo Manifold
Ok so I have a crappy rusted looking log turbo manifold. I am tired of looking at it and so I was wondering is it possible/safe to get some high heat paint and paint the manifold? Or is that not a good idea? If I should do this, sand it a little first to try and get some of the surface rust? Please voice your opinions, good or bad. Thanks.
Re: Painting A Turbo Manifold (Spike101)
u can get it heat coated or wrap in it heat wrap, the paint would prolly just chip off or burn off, i painted a dump tube, **** just turned into power
Re: Painting A Turbo Manifold (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing »</TD></TR><TR><TD CLASS="quote">u can get it heat coated or wrap in it heat wrap, the paint would prolly just chip off or burn off, i painted a dump tube, **** just turned into power</TD></TR></TABLE>
How can I heat wrap a log manifold?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spike101 »</TD></TR><TR><TD CLASS="quote">
How can I heat wrap a log manifold?</TD></TR></TABLE>
wrap with header wrap??
Re: Painting A Turbo Manifold (igo4bmx)
http://www.caswellplating.com/aids/techline/
2000F ceramic, reflects heat, proects from rust, needs no more than a very thin coat. Since it goes on very thin, it means it won't crack or chip off as easy as thick 'BBQ/Grille paint" normally will.
I've painted manifolds with the 1500-2000 degree stuff from VHT and it's always held up nicely. You just need to follow the instructions about proper curing.
Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">I've painted manifolds with the 1500-2000 degree stuff from VHT and it's always held up nicely. You just need to follow the instructions about proper curing.</TD></TR></TABLE>
Sounds interesting. I will look into this. Just dont feel like ordering nothing, rather just go to advance and pick it up.
Re: (inspyral)
Yep, was going to say the same thing.
BobGnarly
05-31-2004 10:10 AM
