B18B T3/T04E 57 trim .48 AR??
i have searched and searched and found nothing but i am planning on running a b18b with t3/t04e 57 trim with a .48 ar turbo at 10psi and was just wonder what i can expect in terms on power? Also when i can expect the turbo spool??
i forgot to add that i will be getting S300
thank you in advance
Modified by BIG T at 5:09 PM 4/11/2007
I made 295whp on a mustang dyno with that turbo on my teg on 10Psig (stock type r). I did massage the comp housing a bit to fit a bigger wheel.
I agree with the poster above..on a stock LS it'll be a bit less..
Re: B18B T3/T04E 57 trim .48 AR?? (BIG T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T »</TD></TR><TR><TD CLASS="quote">i have searched and searched and found nothing but i am planning on running a b18b with t3/t04e 57 trim with a .48 ar turbo at 10psi and was just wonder what i can expect in terms on power? Also when i can expect the turbo spool??
thank you in advance</TD></TR></TABLE>
I have the same setup, im only on 6psi tho. I haven't dynoed my car yet, but i would say around 260 or so, but im just guessing. So i could be way off.
Re: B18B T3/T04E 57 trim .48 AR?? (slowr6)
i ran that turbo .48 on an ls motor. it was crazy responsive. in 3rd gear id see 10psi at like 3500-3800rpms. it started building boost around 2500.
i was so impressed im in the process of piecing together a second turbo kit based aroundthat turbo to run on my daily driver b18b
Re: B18B T3/T04E 57 trim .48 AR?? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">i ran that turbo .48 on an ls motor. it was crazy responsive. in 3rd gear id see 10psi at like 3500-3800rpms. it started building boost around 2500.
i was so impressed im in the process of piecing together a second turbo kit based aroundthat turbo to run on my daily driver b18b</TD></TR></TABLE>
Yeah i love how it spools so fast, its so much fun for the street
LSTDB8
09-01-2005 04:23 AM
asianspeed
11-30-2004 03:17 AM
