Boost creep with Turbosmart MBC
I have a turbosmart MBC on my D16z6(GT28R turbo internally gated) @ 10 lbs and the boost doesn't hold steady. It seems to drop off to about 8 lbs in 4th gear, sometimes it creeps up to 11 lbs then falls to 9-10 lbs. I thought by adding a MBC to my set up it would eliminate my creep issues. I tightened the wastegate actuator arm a couple of turns to try and hold the wastegate from opening prematurly and creeping but no luck. Any ideas or pointers?? A little pic for ***** and giggles.
Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 »</TD></TR><TR><TD CLASS="quote">thats common for all MBC's get use to it or run two of them switch to a turbo xs dual set-up </TD></TR></TABLE>
This WILL end my wavering boost issues for sure?? How are they in comparison to EBC's like the Profec units?
Thanks
Thanks
Re: (jdmsiR20)
I am having a very similar issue w/ my cheap ebay MBC. A new "good" brand MBC will help this? Sorry to thread-jack but I figured since it seems to be the same issue why not.
Also, what exactly does a dual set-up do?
JUST2SPOOL
02-05-2006 09:40 AM
