Timing Question for the well educated?
Old Apr 10, 2007 | 09:19 AM
Running925's Avatar
Default Timing Question for the well educated?
hey guys, i'm gettin ready to put my motor back in & plan to turn the boost up a little more this season. I'm kinda curious, when some of you are hittin 20psi on your t3/t4's what kinda timing are you running in that range.
Are you still sticking with the rule of thumb (.75 retard per pound of boost) or are you doing something different.
I probably won't make it to a dyno for another month or so, i've got a wideband & egt installed so i'll be doing some street tuning (crome pro) & driving before i make it out to the dyno. Just lookin for soem tips.
any help would be appreciated. TIA
Old Apr 10, 2007 | 09:56 AM
eastbay92cx's Avatar
Default Re: Timing Question for the well educated? (Running925)
that sounds like a pretty good idea. you can go with no retard for 1-2psi or so and then step in the retard (.5*/psi for example) until you are at .75-1*/psi once you get up around 20psi. you can try one of the homemade detonation detectors (microphone, or a tube bolted to the engine) if you want to tune on the street, it might be a good idea to have a passenger with you. you might be hard pressed to find someone who will 'give you' some timing values for a similar setup here's a thread relating to this:
https://honda-tech.com/zerothread?id=1555006
good luck. disclaimer i have yet to tune anything
Old Apr 10, 2007 | 10:03 AM
david@didrace.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 &raquo;</TD></TR><TR><TD CLASS="quote">Are you still sticking with the rule of thumb (.75 retard per pound of boost) or are you doing something different.</TD></TR></TABLE>
Wait to get it to the dyno. 20psi untuned as far as timing goes is just asking for trouble.
Kid-jdm-teggy
Engine Management and Tuning
14
Sep 3, 2015 08:18 PM
kameleon23
Aug 23, 2005 08:53 PM
all_out_jdm
May 21, 2005 04:23 AM
turbo Si
Feb 1, 2003 03:59 PM
echo999
Dec 31, 2002 11:28 AM
