Replacing Stock Rodbolts?
Old Apr 12, 2007 | 07:39 AM
GSROWNSU's Avatar
Default Replacing Stock Rodbolts?
Is it safe to reuse the stock rod bolts during a rebuild or should i upgrade to arp? I am already upgrading to arp headstuds but should i upgrade the rod bolts or can i still use the stock ones?
Old Apr 12, 2007 | 10:49 AM
jaggrieger30's Avatar
Default Re: Replacing Stock Rodbolts? (GSROWNSU)
I would definately replace the rod bolts. It is cheap insurance!
Old Apr 12, 2007 | 09:43 PM
GSROWNSU's Avatar
bump! any other opinions?
Old Apr 12, 2007 | 10:04 PM
1995Civic's Avatar
Default Re: (GSROWNSU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSROWNSU &raquo;</TD></TR><TR><TD CLASS="quote">bump! any other opinions?</TD></TR></TABLE>
I would change them as well....at least to another set of stock bolts.
Old Apr 12, 2007 | 11:31 PM
RC000E's Avatar
Default Re: (1995Civic)
I've reused rod bolts more times than I can count. If the rod bolt wasn't stretched beyond it's yeild point then the elasticity of the material will keep its tensile strength intact.
Rod bolts are cheap though, just keep in mind when you replace rod bolts (with either stock or arp's...doesn't matter) you should have the big end of the rod checked for proper roundness. Installing the new rod bolt can distort it and affect clearances.
2ndchirp
Jun 20, 2024 01:15 PM
DefiantGSR
Oct 25, 2008 11:07 AM
b16a4
Dec 11, 2007 05:58 PM
Wazup
Mar 31, 2005 02:58 PM
scUba-stEve
Aug 13, 2004 03:40 PM
