Gt3076R
Old Apr 10, 2007 | 07:55 AM
Kjetil's Avatar
Default Gt3076R
Im going for gt3076r turbo on my full-race setup with piston and rods in my B16 block and wonder if there is somebody who knows what ar i have to go for? and what rpm I will hit full boost on the different trims?
Old Apr 10, 2007 | 08:02 AM
Schister66's Avatar
Man U FTW
Default Re: Gt3076R (Kjetil)
go for the .63ar....if you go for the .82ar i'm afraid it might be a little laggy for a fun street car and at the .63, it will still be plenty of turbo to have fun...
Old Apr 10, 2007 | 08:05 AM
JDogg's Avatar
the 3076 is gona be kinda laggy on a b16. my buddys 3071 hits 15lbs around 5000 rpms, the 3076 will be a few hundred rpms slow as well as be laggier in regards to throttle response at higher rpms.
how much power are you trying to make? we made 466hp/370tq at 20psi on pump gas in the car i mentioned above... 84mm bore b16 with lovefab sidewinder manifold, gt3071, skunk2 intake manifold
Old Apr 10, 2007 | 08:23 AM
LeGeND4LiFe's Avatar
Default Re: Gt3076R (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">the 3076 is gona be kinda laggy on a b16. my buddys 3071 hits 15lbs around 5000 rpms, the 3076 will be a few hundred rpms slow as well as be laggier in regards to throttle response at higher rpms.
how much power are you trying to make? we made 466hp/370tq at 20psi on pump gas in the car i mentioned above... 84mm bore b16 with lovefab sidewinder manifold, gt3071, skunk2 intake manifold</TD></TR></TABLE>
Was that on the .82? If .82, the .63 should be adequate in making it more responsive and still be capable of 466hp, don't you think? Would you mind posting the chart as well, if it's possible.
Old Apr 10, 2007 | 10:02 AM
Kjetil's Avatar
my goals is 400whp with 84,5mm bore
Old Apr 10, 2007 | 10:14 AM
JDogg's Avatar
400hp only.. get the 63ar gt3071, that will be much better than the 3076.
we had the 0.82 ar on my buddys car.. i dont have the dyno graph online, ill try to get it tomm his car made 385 on 14lbs.
Old Apr 10, 2007 | 10:17 AM
AcuraIntegraLS-T's Avatar
i have the 3071 .63ar and it hit 23psi in 3rd by 5000ish and thats on a ls vtec 84.5mm
jody754
Jul 22, 2009 07:25 PM
NOKTURNALCARCLUB
Sep 10, 2007 10:51 PM
93gunner
16
Apr 11, 2007 11:09 AM
88crxhfb16
Apr 15, 2006 08:42 AM
EGP
Jul 29, 2005 02:36 AM
