help my car wont go anywhere drivetrain problem pls help
hi guys well first of i have a b16 with gsr tranny last month i blew my motor so i bought a b16 block but the block is from first gen b16 so i install my head and put the clutch in and i notice thee flywheel on the new (used ) block dont match the pressure plate bolt pattern less hole so i put the 2gen flywheel to the 1 gen block so now the pressure plate and clutch allign the clucth blablah everything is on then i start it and let it warm then i put it in first gear and it wouldnt go anywhere WTF i know i did everything right
so do u think is the flywheel ?
pressure plate?
dont know what to do pls help me guys thaks in advance
pressure plate?
Re: (Sketch_hs)
how do i adjust it i check while my dad steppin on the clutch and its working
is gen 1 b16 flywheel the same as gen2 ?
can i use the gen1 block and put a gen2 clutch flywheel and pressure plate?
thanks alot
thanks alot
BatLude
09-17-2006 05:40 AM
QWKPHKR
03-26-2002 09:23 AM
