84.5 mm sleeves and 84.5mm combustion chambers what compression??
I am getting my gsr block sleeved with 84.5mm sleeves and I am wondering if I should get my combustion chambers matched with the size of the sleeves or not and if I do match the bore and run say an 8.5:1 Piston will my compression be 8.5:1 or lower. Is 8.5:1 a decent compression for this type of build or should I go 9:1?? This is on a boosted application aiming for upwards of 700 whp. If someone can help me out here I would appreciate it.
Re: 84.5 mm sleeves and 84.5mm combustion chambers what compression?? (mikemskater)
are you going to drive this on the street or is a race car. I wouldnt suggest reworking the combustion chamber or it will be a slug on the street. The bigger the chamber the lower to compression will be.
Just my two cents
Just my two cents
ive got an 84mm block with matched 84mm combustion chambers. they measured the volume to 44cc each vs the stock gsr 41.60 which dropped my compression from 9:1 to 8.7:1 so its not too big of a deal.
if you already have the 8.5:1 pistons thats fairly low so its up to you.
its really up to you, i would go with 9:1 as with the reshaped chambers you would be looking at around ~8.1:1 with the 8.5: pistons.
drivability is fine on the street, with the increased displacement u will make way more tq off boost than most boosted setups with stock chambers.
