Injector "dead time"
Old Apr 10, 2007 | 11:16 AM
remmargorp's Avatar
Default Injector "dead time"
Anyone know the typical OEM injector "dead time"?
Old Apr 10, 2007 | 11:29 AM
Finland's Avatar
Default Re: Injector "dead time" (remmargorp)
It varies with injector size, type and system voltage.
Probably more than 1ms, but less than 2ms 'typical'
Old Apr 10, 2007 | 11:35 AM
remmargorp's Avatar
Default Re: Injector "dead time" (Speed Industry)
It's the OE injector.
System voltage is battery: ~14.7VDC
1ms or 2ms is too long.
Total event at idle is 2.5ms
Old Apr 10, 2007 | 11:48 AM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by remmargorp &raquo;</TD></TR><TR><TD CLASS="quote">It's the OE injector.
Total event at idle is 2.5ms</TD></TR></TABLE>
Agreed..my bad..I missed the OEM part
it's probably around .5ms but probably less than 1ms for a small OEM injector.
Only the mfg. will know that answer for certain. Unless you had some nice test equipment.
Old Apr 10, 2007 | 03:12 PM
po_snake's Avatar
Good look finding that information, I've been looking for about a month. Are you running the Emanage Ultimate?
Old Apr 10, 2007 | 09:31 PM
remmargorp's Avatar
Default Re: Injector "dead time" (po_snake)
no. but how's tunability with those guys?
Old Apr 11, 2007 | 01:45 AM
po_snake's Avatar
There are still a lot of bugs in the emanage ultimate and greddy has poor customer service. I've been trying to run rc 550's but you need the lag times for the stock injector and the 550's. There is a place call witchdoctor that can tell you what your lag time is but it will cast you $25. I'm thinking about sending my injectors to get tested. If I didn't have an auto I would just use hondata or something similar because there is more support.
ChokolAwt
Engine Management and Tuning
Feb 18, 2013 11:38 AM
alperx
Sep 20, 2011 08:57 PM
grimmer
Feb 13, 2007 08:56 AM
CRX_Control
Nov 13, 2004 07:35 PM
stupidfast
Aug 27, 2003 06:31 AM
