Compressor outlet and piping clearance problem
I've been looking around for a bit and can't locate a solution on HT. What are my options? (T3/T04E and inlinepro on DC2) Thanks
Sorry, should have clarified - the problem was ground clearance. In the picture it looks like a chassis interference, but that's not the case.
Ok, I like the idea of a silicone 90. Hopefully that will have a LOT tighter radius. Too bad I can't locate a 2" to 2.75" reducer elbow, but I'll manage.
I had a thought, but it will involve a change in the pipeing. You could cut the piping further down, use your reducer, add a smaller diamiter pipe and use a 2in 90. Little work but I would see it as a viable alternative.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greasemonkee »</TD></TR><TR><TD CLASS="quote">Ok, I like the idea of a silicone 90. Hopefully that will have a LOT tighter radius. Too bad I can't locate a 2" to 2.75" reducer elbow, but I'll manage. </TD></TR></TABLE>
you can have samco make you one, but it will probly cost 65 bucks and take 4 months.
they made me a 3-2" 90* reducing elbow. i ordered it in december, got it like 2 weeks ago. super nice stuff, but it had to be made in the UK or something like that. you might luck out if they have em stocked. id link you but i cant find it.
Modified by bch5428 at 3:23 AM 4/8/2007
did you try clocking the turbo back so the inlet is back by the oil pan? that looks like it might give you a few inches? what kind of suspension are you running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">i would get a cast aluminum 90, they are much tighter on clearance, pop the compressor cover off and take it to a welder and let him fix er' up</TD></TR></TABLE>
easiest thing to do
easiest thing to do
clock the turbo so that the compressor outlet is facing up toward the hood. Then redirect the piping and cut a whole in your wheel well guards, and keep the charge pipes going until the intercooler
BodyKits NW
Welding / Fabrication
Oct 8, 2005 09:22 PM
Rain_man
Jul 15, 2004 12:11 PM
phiberoptik
Feb 25, 2004 12:21 PM
