Need help with setting with safc on sohc..
Old Nov 8, 2003 | 01:55 PM
BoostedD15B7's Avatar
Default Need help with setting with safc on sohc..
Can anyone help me out and tell me about what settings i should be running on high and low correction. The motor is 1.5 sohc, 450 cc dsm,255 intank fuel pump,safc2, stock head, 8psi.
Old Nov 8, 2003 | 02:31 PM
Slammd Sol's Avatar
Default Re: Need help with setting with safc on sohc.. (BoostedD15B7)
Heres my setup and settings:
<U>Dyno tuned</U> D15b7 @ 6 psi w/ DSM 450's and SAFC
settings are same for high and low
1000: -19
2000: -33
3000: -35
4000: -37
5000: -33
5500: -35
6000: -43
6500: -43
Old Nov 8, 2003 | 02:36 PM
Default Re: Need help with setting with safc on sohc.. (Slammd Sol)
Why are you taking away fuel as your rpms increase? you have -19 at 1000rpm. Isnt that real rich?
Old Nov 8, 2003 | 03:18 PM
Slammd Sol's Avatar
You would think it would be rich.. But its what the shop set it to. Runs and idles perfect..
Old Nov 10, 2003 | 07:03 AM
anyone else?
Old Nov 10, 2003 | 07:07 AM
Johnyquest's Avatar
well, my settings aren't dyno tuned, and are rather different from the above, but both me (d16z6, 255intank + dsm450s) and my friend (d15b7) are using them:
crossover 70/71%
......LO........HI
1k..-34.......-38
2k..-35.......-38
3k..-35.......-38
4k..-35.......-38
5k..-35.......-38
6k..-35.......-38
7k..-35.......-38
8k..-35.......-38
Old Nov 10, 2003 | 07:23 AM
boosted_dc2's Avatar
Default Re: Need help with setting with safc on sohc.. (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">well, my settings aren't dyno tuned, and are rather different from the above, but both me (d16z6, 255intank + dsm450s) and my friend (d15b7) are using them:
crossover 70/71%
......LO........HI
1k..-34.......-38
2k..-35.......-38
3k..-35.......-38
4k..-35.......-38
5k..-35.......-38
6k..-35.......-38
7k..-35.......-38
8k..-35.......-38
why do you have less fuel in high throttle???? i wouldnt do this, i was running the hack only to find out it was the dumbest thing i did.
Anyways my settings were
low
1-4 k -36%
4k -35%
5-6k -34%
7-8k -33%
High
1-3k -36%
and then it varies all the way up to 9k, i was running on a b18c with rc 440's. at some rpm incriments the corrections were -28%. i have the numbers writen down at home.
However i would not run the hack, im speaking form expierience that its bad news. it inconsistant plus the fact that it adds a shatload of timing.
Old Nov 10, 2003 | 07:57 AM
InTeGrA B18b1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol &raquo;</TD></TR><TR><TD CLASS="quote">Heres my setup and settings:
1000: -19
2000: -33
3000: -35
4000: -37
5000: -33
5500: -35
6000: -43
6500: -43</TD></TR></TABLE>
you got some messed up settings
Old Nov 10, 2003 | 09:26 AM
Johnyquest's Avatar
Default Re: Need help with setting with safc on sohc.. (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
However i would not run the hack, im speaking form expierience that its bad news. it inconsistant plus the fact that it adds a shatload of timing.</TD></TR></TABLE>
10k miles on both cars and still going strong. zero detonation. i'll PM you when it blows up. until then, I swear by the hack.
Old Nov 10, 2003 | 11:03 AM
Slammd Sol's Avatar
Default Re: Need help with setting with safc on sohc.. (InTeGrA B18b1)
Its what the shop set it at.. I made numerous pulls on the dyno, and those settings had the best air/fuel #s
Old Nov 10, 2003 | 11:22 AM
so you decreased the fuel as the rpm rises. i dont get it why that would work. Does you turbo die off and you just lean it out or something&gt;?
Old Nov 10, 2003 | 11:49 AM
wc's Avatar
wc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">so you decreased the fuel as the rpm rises. i dont get it why that would work. Does you turbo die off and you just lean it out or something&gt;?</TD></TR></TABLE>
Just because he's leaning out the AFC at high RPM, doesn't neccessarily mean there is less fuel. Remember, the fuel map inside the ECU is non-linear. So at high RPM, there may be more fuel then is needed. Wideband AF sensor is the only way to be sure.
- wei
Old Nov 10, 2003 | 07:06 PM
scttydb411's Avatar
Default Re: Need help with setting with safc on sohc.. (wc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc &raquo;</TD></TR><TR><TD CLASS="quote">
- wei</TD></TR></TABLE>
i just got done explaining my settings as well on hmt. 10-11psi on the hack and my hi settings are almost all -50.
NEVER use someone else's settings. set your lo corrections to like -46 to get an equivalent of 240cc and make the hi corrections what you would think to be richer. get it WIDEBAND tuned and lean them to the proper corrections getting you to 11.5-12.5 afr.
Old Nov 11, 2003 | 03:32 AM
Default Re: Need help with setting with safc on sohc.. (scttydb411)
How much does the hack advance the timing. Thats what my problem is im getting just a hair of detonation. What should the timing be set to
Old Nov 11, 2003 | 07:29 AM
.5-1 degree for every psi to be very safe. or .33
Old Nov 12, 2003 | 03:32 AM
so i should set the timing to like 12 degrees?
Old Nov 12, 2003 | 10:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">so i should set the timing to like 12 degrees?</TD></TR></TABLE>
no hes talking about like a msd btm. (i think) retard your timing like 5 degrees and then see if you have detonation.
Old Nov 12, 2003 | 01:46 PM
On the distributor or btm?
Old Nov 14, 2003 | 03:16 AM
NOw that i have the 450cc inj the car has to turn over a few times before starting. Is this normal or should it fire right up like stock? Setting off maybe?
Old Nov 14, 2003 | 06:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">On the distributor or btm?</TD></TR></TABLE>
if you got btm do it on btm. iF not do the dizzy
1750cc
Oct 18, 2005 08:51 PM
1boostedcivic
Apr 29, 2005 10:43 AM
Onesickcrx
May 21, 2003 11:38 PM
BoostedD15B7
Oct 23, 2002 07:35 AM
JoshM
May 28, 2002 06:14 AM
