Cam suggestions for N2o+H22 setup?
Old Nov 8, 2003 | 11:54 AM
NirVTEC's Avatar
Default Cam suggestions for N2o+H22 setup?
I notice that most beginner FI guys use stock cams. I was originally looking into Crower Stg2 before I decided to go with N2o......
I am going to run an 80 shot with stock internals, but after the build I would like to add cams. Would the Crower still be an option or would some sort of custom grind be the way to go. I am looking to run a 100-125 DP setup after I build the guts.
I feel like a newbie all over again in the FI world!
-clint
Old Nov 8, 2003 | 12:18 PM
ITRswapandslow's Avatar
http://www.hondaraceengines.com
Brad can make you some custom ground cams...with the proper specs for your setup.
Old Nov 8, 2003 | 01:24 PM
JSMC's Avatar
Default Re: (eh2nboost)
is he grounding stock cams or just made completly new one?
Old Nov 8, 2003 | 01:39 PM
COMPLETELY new
Old Nov 8, 2003 | 01:41 PM
$750 a set
and they are COMPLETELY new grinds and cores
these are CUSTOM. They are made for your application specifically.
Old Nov 8, 2003 | 02:06 PM
JSMC's Avatar
are they good enough to help us find the good way to have the perfect grind?
Old Nov 8, 2003 | 02:16 PM
just talk to brad
Old Nov 8, 2003 | 04:22 PM
JSMC's Avatar
aiight
Old Nov 8, 2003 | 04:55 PM
h22 civic's Avatar
Default Re: (JSMC)
what material?
Old Nov 8, 2003 | 05:35 PM
only the best obvioulsy
Old Nov 9, 2003 | 05:09 AM
bump for not only H..but also B series cams
harhoosh
Oct 29, 2011 12:42 AM
tepid1
May 12, 2010 06:37 PM
supra-n-civic
Nov 4, 2009 02:25 PM
Quick Silver
Apr 22, 2003 02:55 AM
