some kind of knock...what is it
Old Nov 9, 2003 | 06:09 PM
baddassduramax's Avatar
Default some kind of knock...what is it
ok, heres the deal, finished rebuilding and putting motor in saturday morning at 800am, a little hard starting but got it started and have about 80 miles, runs strong, pulls hard...but
the big issue is, all valves adjusted 4 times to correct clearance, compression tested #1-175, #2-150, #3-175, #4-175 (tested after 70 miles), it sounds like there is some sort of knock in the motor, i am pretty sure its not the valves ticking and when i get close to the pan i can hear it more than when standing over my motor. do you think it could be a rod bearing? i kind of thought that it may be #2 because the compression is a little lower. well let me knwo and thanks in advance.
Old Nov 9, 2003 | 06:12 PM
rjardy's Avatar
Default Re: some kind of knock...what is it (civicb18)
forged internals?
Rob
Old Nov 9, 2003 | 06:14 PM
redboost10's Avatar
Default Re: some kind of knock...what is it (rjardy)
forged pistons will rattle
oh yea, sorry bout that, i have srp pistons 9.2:1, and eagle rods, which were in my motor that cracked the wall before, had them checked, and AOK
Old Nov 9, 2003 | 06:22 PM
Default Re: some kind of knock...what is it (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">forged pistons will rattle</TD></TR></TABLE>
not really a rattle, more of a knock and also, when it comes to idle it will do it and if it sits and idles for a minute or so, it will go away then come back and so on
Old Nov 9, 2003 | 06:28 PM
redboost10's Avatar
yeah i know what you mean i had the srp 9:1 pistons and its like a rattle knock or whatever, its normal. yeah it goes away and comes especially when its just idling sitting there.
Old Nov 9, 2003 | 06:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">yeah i know what you mean i had the srp 9:1 pistons and its like a rattle knock or whatever, its normal. yeah it goes away and comes especially when its just idling sitting there. </TD></TR></TABLE>
but it didnt seem to do it when i had them in my last block, could it be just a tighter clearance on my new one?
Old Nov 9, 2003 | 10:48 PM
ttt
Old Nov 10, 2003 | 04:40 AM
morning bump
Old Nov 10, 2003 | 07:26 AM
Tinker219's Avatar
or looser tolerances, ie, sloppy in there.
Old Nov 10, 2003 | 07:32 AM
30psi Teg's Avatar
Default Re: some kind of knock...what is it (Tinker219)
yeah do you know what piston to wall clearance you are running. Probably just a little slapping goin on.
Old Nov 10, 2003 | 07:35 AM
metal-x's Avatar
Default Re: some kind of knock...what is it (30psi Teg)
I think i have the same problem here is my post
https://honda-tech.com/zerothread?id=631614
and I have video clip of the sound my motor makes does this sound like yours?
http://65.49.87.73/MotorSound.avi
Old Nov 10, 2003 | 09:57 AM
Default Re: some kind of knock...what is it (metal-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">I think i have the same problem here is my post
no, its nothing like that, mine has a knock a lot slower, its not real fast, at idle (800rpms or so) it sounds like it knocks everytime the cam makes on full rotation (just giving an idea about the speed of the knock). and it sounds more like you are knocking on a wooden door than a ticking.
Old Nov 10, 2003 | 12:35 PM
one more bump
DecepticonDc5
Honda S2000
18
May 14, 2009 10:41 AM
scspeed
Sep 16, 2008 05:12 PM
JDM_SOHC
Mar 24, 2008 09:19 AM
SpoolnByYou
13
Jan 4, 2007 12:14 PM
Boostage
Oct 18, 2004 08:09 AM
