n1 for catback?
Old Nov 9, 2003 | 05:20 PM
blu2ksi's Avatar
Default n1 for catback?
i was wondering if the n1 piping is big enough to run a turbo ? i wanted the thermal 3 " but i can afford that at the moment, if i took out my cat and ran straight pipe, would the pipe be too small or could it work?
Old Nov 9, 2003 | 05:24 PM
illi Adik's Avatar
Default Re: n1 for catback? (blu2ksi)
Look up KTeller on this board, he can hook you up with a sweet 3'' and your choice of muffler for cheap.
Old Nov 9, 2003 | 05:40 PM
rjardy's Avatar
It will be allright if you are not looking to make allot of power. whats your setup?
Rob
Old Nov 9, 2003 | 05:43 PM
blu2ksi's Avatar
Default Re: n1 for catback? (rjardy)
drag gen 111 kit, nothing special, stock injectors for now , but upgraded fuel pump, i only want like 8 psi max so i didnt want nething extreme
Old Nov 9, 2003 | 06:02 PM
Chrome Pipes's Avatar
We ran an N1 catback on my brother's DRAG III GS-R and it was fine. If I recall the N1 is 2 1/4 in diameter. He bought the exhaust when we first did the swap and it was all-motor. When we put the turbo kit on, instead of buying a new exhaust, we welded in a Y-pipe cutout that had a removable plate with three butterfly nuts. When the slicks were going on at the track I just reached under the car and unbolted the plate, it only took a couple of seconds. The cutout was like $25. Its not as good as a full 3 inch catback, but it worked
Old Nov 9, 2003 | 06:05 PM
rjardy's Avatar
Default Re: n1 for catback? (Chrome Pipes)
Personally i would say its fine. When I was going to boost my civic (before i bought my project money pit) i bought that exhaust. Low boost it will be fine. D series motor?
Rob
Old Nov 9, 2003 | 06:22 PM
PM-Performance's Avatar
even if you wanna make big power its ine , i was making close to 400whp on low boost with it on , still on at the moment to see how much i can make on it before switching out to 3inch
shadykit
Apr 4, 2005 12:16 PM
OEMaccord96
Dec 8, 2003 03:52 PM
xxxxspdrcr
Jul 15, 2003 10:53 AM
92JDMSiR
May 5, 2002 06:37 AM
Rob!
Feb 1, 2002 01:57 AM
