What cams to run in an LS/Vtec
Old Nov 6, 2003 | 11:23 AM
underpressure02's Avatar
Default What cams to run in an LS/Vtec
I have a 99ls bottom end, with a b16 head. Right now I am running ctr cams in the B16 head. Some people are saying to run gsr some are saying to run type r cams. What do you guys recommend? Forgot to add I am running the drag turbo kit on the motor.
Old Nov 6, 2003 | 12:13 PM
boosted hybrid's Avatar
Default Re: What cams to run in an LS/Vtec (underpressure02)
Just use the cams in the engine now. You'll pick up a bit of power with the ctr's. You'll notice that they hold the torque a little longer to redline, giving you a higher peak whp number.
Old Nov 6, 2003 | 01:08 PM
Johnyquest's Avatar
Default Re: What cams to run in an LS/Vtec (boosted hybrid)
Yeah, your cam's are top notch.
You need to tune the overlap out, though, with a set of cam gears. I'm not sure what the correct settings should be, but a trip to the dyno and a good set of cam gears would make some nice power, if you haven't already.
Otherwise, your boost partially blows right out your exhaust!
Old Nov 6, 2003 | 01:57 PM
-Trinitron-'s Avatar
I have always heard the GSR cams were best for LS VTEC Turbo. The Big NA CTR cams have issues with the overlap and the GSR would be better suited for that. I'm not an expert, please correct me if I am wrong.
Jdm_Ej8_Sedan
Feb 25, 2014 05:04 PM
bigislandc2
Aug 10, 2006 01:56 PM
93lsvtecteg
Oct 6, 2005 07:32 AM
jdmek910
Nov 21, 2004 05:41 PM
MysteriousGSR
Apr 15, 2002 06:47 PM
