quiet bov?
Old Nov 9, 2003 | 01:35 PM
prettyQuik's Avatar
Default quiet bov?
I really would like my car as sleeper as possible. i have a ls hatch with the drag gen 3. the blitz bov is already kinda quiet, but i've heard theres a way to reduce almost all of the sound? let me know of any way
Old Nov 9, 2003 | 01:47 PM
Ricey McRicerton's Avatar
Default Re: quiet bov? (rexboyb18)
If you could rerout the BOV to blow under the car or back into the exhaust, it will be virtually silent.
Old Nov 9, 2003 | 01:50 PM
Joseph Davis's Avatar
Default Re: quiet bov? (Ricey McRicerton)
Ricey means blow off back into the intake tract before the turbo, so it's muffled. (alomst?) All OPEM cars are like this.
u2civic1's Avatar
"If you could rerout the BOV to blow under the car or back into the exhaust, it will be virtually silent."
i don't kno about puting it back to the exhaust but putting it under the car works great ive done this before for daily driving so the cops don't pull me over
but people will still hear the spool of the turbo
Old Nov 9, 2003 | 02:37 PM
ITRswapandslow's Avatar
tial's are quiet from what i've been told
check sig
Old Nov 9, 2003 | 03:21 PM
gdrum's Avatar
Default Re: (eh2nRLZenginey0)
ive heard boschs or yeah get like a VW oem diverter valve and hook it up....
Old Nov 9, 2003 | 03:46 PM
TurboJesse
Guest
Posts: n/a
Default Re: (gdrum)
1st gen DSM bov's are pretty quite and if crushed work with high boost.
Old Nov 9, 2003 | 03:58 PM
2K_TEG's Avatar
Default Re: (Mpir3)
GReddy type R is not loud, plus it is threaded so you can route it anywhere.
Kyle
Old Nov 9, 2003 | 04:03 PM
prettyQuik's Avatar
Default Re: (2K_TEG)
awesome...ill look into all that
thanks for the help
Old Nov 9, 2003 | 04:14 PM
go with a tial
i need to get rid of mine..it's BRAND NEW
Old Nov 10, 2003 | 12:07 AM
integrx's Avatar
New User
Default Re: quiet bov? (u2civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 &raquo;</TD></TR><TR><TD CLASS="quote">"If you could rerout the BOV to blow under the car or back into the exhaust, it will be virtually silent."
i'm pretty sure its called bypass valve, instead of blow off
Old Nov 10, 2003 | 12:47 AM
TeStUdO's Avatar
Well if its routed back in the intake like on DSM's they are virtually silent. Just adding onto what J Davis said.
Old Nov 10, 2003 | 05:14 AM
Default Re: quiet bov? (integrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrx &raquo;</TD></TR><TR><TD CLASS="quote">
i'm pretty sure its called bypass valve, instead of blow off</TD></TR></TABLE>
They are essentially the same thing, only bypass valves are almost never fully seated in low vacuum situations. You can't have them "blowing off" into the atmosphere on a MAF equipped vehicle and have the vehicle run right.
I run the Bosch unit on my CRX, in a MAP aka speed density setup it works very well as a BOV.
Old Nov 10, 2003 | 08:35 AM
gdrum's Avatar
Default Re: quiet bov? (J. Davis)
hks makes a electronic regulator...to run bov on maf units.....its like 300 bux to my knowledge...as far as i know
Old Nov 10, 2003 | 08:44 AM
tegmech's Avatar
bypass valve- Closed Loop
blow off valve-Open Atmosphere system
Although correct me if im wrong
Closed loop system is why the dsm is quiet.
EG6Honda
Jul 25, 2005 08:23 PM
zeroz
Apr 14, 2005 11:52 AM
ijjz
Feb 17, 2003 06:24 PM
shamoo
Sep 25, 2001 01:11 PM
SIK IN DA HED
Jun 16, 2001 02:47 PM
