b18a block how much psi can it handle
Re: b18a block how much psi can it handle (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">Search, and you will find your answer </TD></TR></TABLE>
Re: b18a block how much psi can it handle (quick1racer)
Depends on the size of your turbo. Manifold pressure is just a measurement. You should be asking how much hp it can handle. Please search.
Re: b18a block how much psi can it handle (highmilehatch)
you can search but im board and I will be nice and give you your answer, you can get around 18psi with a good standalone tuning and at least 550 injectors tuning is the key. 15psi safely and that should put down a good 280 whp -320 whp on a ls. do you have any headwork? what turbo are you gonna use? get a sc61 and I would guarantee in the mid 300's for whp with the help of hondata or ems. Good luck.
Re: b18a block how much psi can it handle (BoostedsiR)
There was a guy i beleive "willis" with same setup, pistons/rods and he was running hondata at 1 bar, he made 315/300
integraboosted
11-13-2005 06:11 PM
