h22 bore
Old Nov 9, 2003 | 05:32 PM
m.'s Avatar
m.
Default h22 bore
what is the max bore one can do to a h22 before sleeving without worrying? i'm deciding to run serious boost over 25+psi with sleeves. just concerned about getting in the worst case scenrio if there was a mistake while boring, will i have room to redo. please help me out.
Old Nov 9, 2003 | 05:37 PM
accordm3's Avatar
Default Re: h22 bore (STOCK)
when you sleeve i would go with stock bore simply because... if u **** ur **** up you can bore it out and get bigger pistons... if you bore it like 90 mm then when it ***** up your block is trashed
Old Nov 9, 2003 | 05:49 PM
m.'s Avatar
m.
Default Re: h22 bore (accordm3)
i know that but i have no intention to max it out the bore because i wanna know how far one can go. just wanted to know the limit.
Old Nov 9, 2003 | 06:04 PM
JSMC's Avatar
with golden sleeve i've been told that you can go to 89mm for boosted engine with no problem, so that's what i'll do, and that may be the max you want to go!
Old Nov 9, 2003 | 06:35 PM
spoolinlude's Avatar
I live under a rock
Default Re: h22 bore (JSMC)
91mm max bore NA cars only
89mm max bore FI, with headgasket problems
keep it under 88mm, you can make more power elsewhere
EDIT: only go .5mm above stock (87mm) if you want a rebore out of it, you could probably go higher, but whats the point? Half a mm is how big?? 15 thousandths?
Old Nov 9, 2003 | 07:44 PM
BoostedH23a1's Avatar
Default Re: h22 bore (spoolinlude)
dlb is runnin 90 or 91mm with turbo... curious to see how it holds up.. i would go with 87-88 or so
Old Nov 9, 2003 | 11:24 PM
DLB1994's Avatar
Default Re: h22 bore (BoostedH23a1)
am running 90mm with a copper headgasket with SS o-rings in the head
Old Nov 10, 2003 | 04:40 AM
m.'s Avatar
m.
Default Re: h22 bore (DLB1994)
thanks for the replies guys. any other comments is appreciated.
Old Nov 10, 2003 | 01:21 PM
buh_buh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">when you sleeve i would go with stock bore simply because... if u **** ur **** up you can bore it out and get bigger pistons... if you bore it like 90 mm then when it ***** up your block is trashed</TD></TR></TABLE>
Can't you just replace the sleeves?
Old Nov 10, 2003 | 01:30 PM
accordm3's Avatar
i believe you can... but the block isnt the expensive part... its the sleeves
Old Nov 13, 2003 | 03:00 PM
m.'s Avatar
m.
Default Re: (accordm3)
so would there be a noticable difference while boosting (spool time) between 87mm vs. 89mm using a t4 turbo? what's the displacement of a h22 going to 89mm?
Old Nov 13, 2003 | 03:12 PM
accordm3's Avatar
not much... what are the specs on the turbo
Old Nov 13, 2003 | 03:45 PM
m.'s Avatar
m.
thinking about the big boy pt67 gtq. .70 a/r compressor housing and a .68 rear.
Old Nov 13, 2003 | 04:08 PM
I live under a rock
Default Re: (STOCK)
hello lag, my name is too big for the street, .70a/r, yikes
Old Nov 13, 2003 | 04:27 PM
m.'s Avatar
m.
Default Re: (spoolinlude)
yea i know there's gonna be lag, i have no intention to race on the streets. my thoughts were to prove h22 have a part in the turbo community in making hp.
H23ALL
Apr 8, 2014 05:01 AM
H22Luda720
Mar 20, 2006 01:33 PM
H22Luda720
Mar 20, 2006 05:35 AM
H22Luda720
Mar 20, 2006 02:40 AM
h22dx
Apr 15, 2003 01:07 PM
