E-cutout seals well???
E-cutout users, how well do your e-cutout's seal when the set to fully closed??? I noticed in this post https://honda-tech.com/zerothread?id=568844&page=2 that there might be problems with it fully sealing properly. How well has it held up for you? BTW - Please mention which brand you are using QTEC or McCord Power Plate 2 (aka MCPP2) and for how long!
mccord or quicktime, they both will seal "well" in the beginning. After opening and closing them a few times they will be prone to have a small leak which is i guess somewhat expected.
The 3 I went through eventually fell apart
(The two screws actually holding the motor assembly in vibrated loose and the whole motor came apart. Loctite didn't help in scenario #'s 2 and 3
best thing i've heard was to spot weld the 2 screws that holds the plate down. and about the sealing, people have used silicone gasket around the edges to help it seal.
damn....that's *really* bad if it's prone breaking at the same spot over & over
.... r u on #4 now? Anyone else have the same experiences with sealing & breaking too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4sol »</TD></TR><TR><TD CLASS="quote">
.... r u on #4 now? Anyone else have the same experiences with sealing & breaking too?</TD></TR></TABLE>
i am really trying hard to come up with a better way of doing this. butterfly valves just wont work.
i haven't had the inspiration yet though. too much
.... r u on #4 now? Anyone else have the same experiences with sealing & breaking too?</TD></TR></TABLE>i am really trying hard to come up with a better way of doing this. butterfly valves just wont work.
I'm running 2 qtec's on my car, I spot welded the screws down and leakage isn't a problem/big problem for me. I'm sure it leaks a little bit, but it doesn't sound like it's still half open or anything.
There is another one that is made that instead of using a butterfly, uses a slide door on it... It was shown on Trucks TV, but is like $230 a piece
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi »</TD></TR><TR><TD CLASS="quote">There is another one that is made that instead of using a butterfly, uses a slide door on it... It was shown on Trucks TV, but is like $230 a piece</TD></TR></TABLE>
where can i read about it?
No...just decided on a full 3" stainless turbo back instead. Less hassle.
Will keep in mind the spot welding though.
.... r u on #4 now? Anyone else have the same experiences with sealing & breaking too?</TD></TR></TABLE>No...just decided on a full 3" stainless turbo back instead. Less hassle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falconGSR »</TD></TR><TR><TD CLASS="quote">
This is what it looks like on the truck...
I cant remember what its called though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewspeed »</TD></TR><TR><TD CLASS="quote">mccord or quicktime, they both will seal "well" in the beginning. After opening and closing them a few times they will be prone to have a small leak which is i guess somewhat expected.
which ones did you use? I have 2 qtecs and they work perfect. ive had them on for awhile and no problems. to seal it, they recommend rtv silicone. i justed used hondabond and it works great. no leaks
</TD></TR></TABLE>which ones did you use? I have 2 qtecs and they work perfect. ive had them on for awhile and no problems. to seal it, they recommend rtv silicone. i justed used hondabond and it works great. no leaks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">I'm running 2 qtec's on my car, I spot welded the screws down and leakage isn't a problem/big problem for me. I'm sure it leaks a little bit, but it doesn't sound like it's still half open or anything.</TD></TR></TABLE>
what car are you running two on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan »</TD></TR><TR><TD CLASS="quote">
which ones did you use? I have 2 qtecs and they work perfect. ive had them on for awhile and no problems. to seal it, they recommend rtv silicone. i justed used hondabond and it works great. no leaks</TD></TR></TABLE>
Used the Quicktime ones.
Used the Quicktime ones.</TD></TR></TABLE>
how long did you have it for before it fell apart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.K.C. »</TD></TR><TR><TD CLASS="quote">Does anyone have experience with the McCord E-cuts?</TD></TR></TABLE>
i have heard a lot of bad stuff about the mccords. Before i got my quicktime, i was researching all of em. I heard bunch ofstories about the mccords and almost everyone had problems with them.
I got an idea. everyone that has had a problem, THEN FIXED IT post what you did to FIX it and better it. that would be cooool I plan on ordering mine soon.
I am thinking of putting mine on a flax pipe to get rid of rattles.
Well, with the Quicktimes, I do think the suggestion of spot welding the two screws/bolts on the motor assembly may work.
As seen in the pic I posted of my setup, vibration has a lot to do with those screws/bolts shaking loose. Loctite did not help in this case.
I do remember a while back someone stating maybe placing the e-cutout farther back in the exhaust to eliminate high vibrations - not sure how you would set this up especially if your running anything bigger than 2.5"
The first one broke say after 3 months of rigorous opening and closing. I was basically the guinea pig at the shop for this setup so he told me to use it as frequent as I could.
The next one, the butterfly actually fell off. Fixed that by riveting it on, then the motor assembly fell apart again
Went to a third but by that time, I was a little fed up and decided that having a loud car isn't that bad
Fixed = full 3" stainless exhaust
EG-SIXV-TEC
May 2, 2012 06:28 AM
mattbatson
16
Mar 3, 2012 09:46 PM
petty$rep
Oct 13, 2006 08:39 PM
