Spark plug gap & Emissions
Old Nov 7, 2003 | 05:35 AM
Canuk_SiR's Avatar
Default Spark plug gap & Emissions
I'm just curious if the gap in the plugs has a big impact on emissions. I've failed my first emissions test, and am trying to figure out everything that I should look into to prevent another failure, and so far, have changed out the cat with a brand new one, and run super lean for the test. BUT, will my current plug gap (0.030") be bad? Should I get a new set of plugs, like oem's, and have an oem gap for the test? My first test, I barely failed the 40 kph test, but failed miserably on the idle test.
Also, anyone have any other ideas as to what could help me pass emissions? I've got 1 week to get my car to pass
Old Nov 7, 2003 | 08:21 AM
racerxadam's Avatar
Default Re: Spark plug gap & Emissions (Canuk_SiR)
running too lean can also cause you to fail emissions. here is a pic relating the five measured gases and how air/fuel ratio effects them.
Old Nov 7, 2003 | 08:49 AM
Canuk_SiR's Avatar
Default Re: Spark plug gap & Emissions (racerxadam)
thanks for that chart, it helps alot!
I looked at my readings, and I was way too rich for idle. I logged my test, and I had something around 11.5:1 afr at idle! My car was idling too low, and since I never tuned for a real low idle, it was way too rich..
DB1_559
Apr 1, 2011 01:48 PM
lude98SH
Sep 21, 2008 04:58 AM
rasinhell
Feb 22, 2005 11:06 PM
IH82LOSE
Jul 31, 2004 05:20 PM
