Stock sleeve capability
Old Nov 9, 2003 | 07:10 PM
Jer Del Sol's Avatar
Default Stock sleeve capability
What can the stock sleeve handle? will it be able to take up to 12-14psi?
Old Nov 9, 2003 | 07:14 PM
11psiTurboSI's Avatar
Default Re: Stock sleeve capability (Jer Del Sol)
I run 16psi on stock sleeves, so 12-14psi should be fine with good tuning... Some people run 23psi on stock sleeves
Old Nov 9, 2003 | 07:19 PM
avex's Avatar
12-14 psi from a small turbo..say a td05h is going to be way different from an sc-61 running 12-14 psi..what turbo are you planning on using?
Old Nov 9, 2003 | 07:25 PM
just a garrett T25
Old Nov 9, 2003 | 08:16 PM
what mods do you guys have?? i just have eagle rods and je pistons... 9.5:1 compression... will my stock block be able to handle 14psi? reason y i ask is because i had a turbo spike and my pistons are gone
Old Nov 9, 2003 | 08:18 PM
Jared's Avatar
Default Re: (Jer Del Sol)
9:1 Arias, eagle rods, i went 11.4 at 129 on 20psi stock sleeves, several guys on this board are in the 10s at 135 or so with stock sleeves.
Old Nov 10, 2003 | 01:06 AM
Jdm_Rice_Monster's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">9:1 Arias, eagle rods, i went 11.4 at 129 on 20psi stock sleeves, several guys on this board are in the 10s at 135 or so with stock sleeves.</TD></TR></TABLE>
What motor, and what car?
Old Nov 10, 2003 | 01:15 AM
Mr. Softee's Avatar
Default Re: (Jdm_Rice_Monster)
there are guys in the 10s with stock pistons / rods
Old Nov 10, 2003 | 09:50 AM
TurboJesse
Guest
Posts: n/a
Default Re: (94goldjungsr)
Its gonna take alot of power to crack a stock sleeve without detanation...if the car is tuned well it can easily handle over 500whp...the amount of boost its running really means nothing...Im running 1bar with all stock internals on a 60 trim t3/t04e...alot bigger than your turbo.
Old Nov 10, 2003 | 10:35 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (Mpir3)
I have seen 27psi on an sc61 and a 75 shot on the SFP integra on stock sleeves with block guard. I actually drove the car at 27psi w/o the nitrous so i know it was no BS. How long it will last i have no idea but it has held for while so far.
k20coupe
Sep 1, 2008 12:58 PM
the.hamburglar
Sep 29, 2005 05:59 AM
gamakichi77
Nov 1, 2004 05:46 PM
Power Rev Racing
Sep 27, 2004 08:36 PM
fknfast
Feb 2, 2004 01:02 PM
