JRSC? Whats required to......
Old Nov 9, 2003 | 05:30 PM
JRSC EM1's Avatar
Default JRSC? Whats required to......
I have a JRSC on my 2000 Si. I would like to know what I would need to get to be able to use that supercharger on my 95 Civic CX with a B18C1. I know the manifolds are different but is there anything else I would need to get? Plus where would be a good place to get the GSR Jackson manifold? Thanks in advance for your help.
Old Nov 9, 2003 | 08:18 PM
JRSC EM1's Avatar
Default Re: JRSC? Whats required to...... (JRSC EM1)
Back to page one. Come on someone has to know this.....
Old Nov 10, 2003 | 10:12 AM
funky_cornbread's Avatar
The b16, b18c1, type r JR kits all use the m62 blower and bolts up to the head in the same order. I believe the only thing different are the pulleys themself but don't quote me on that. Just make sure everything is torqued properly, loc-tite'd properly and all gaskets are accounted for, OEM and JR.
Old Nov 11, 2003 | 10:26 AM
roadrunner's Avatar
The GSR manifold-head bolt pattern and water outlet is different from that on the B16/ITR manifold. They are not a direct swap. I'm not sure about the alternator upper mount/tensioner as the GSR block is a little taller. The upper mounting point of that mount/tensioner can adjust but I don't know it it has enough range to account for the different block heights. I think the difference is only about 10mm (7mm longer stroke, right?)
DexterThEG
Dec 25, 2004 06:47 PM
Roky
Jun 1, 2004 03:21 PM
jdmhatch94
Feb 27, 2003 08:38 AM
jdmhatch94
Feb 26, 2003 06:25 PM
