Tial 35mm wastegate w/12 psi spring but I only want 6-8 PSI right now
HELP? Tial 35mm wastegate w/12 psi spring but I only want 6-8 PSI right now
I got a b18b and im going to be using a T3/T04E 57 trim .63 a/r turbine,
I have a 12 PSI spring in my 35mm Tial Wastegate. What does this mean?
Can I choose to run only 6 PSI if I would like to by using a boost controller or something? maybe 8 later but i want to stay away from the 12 PSI for right now as i'd like my internals done before that amount or higher boost. I want to stay conservative.
So far i havent been able to understand what the boost spring does, or how it's bypassed with a boost controller, my thoughts might be way off, can someone gice me a descriptive rundown and point me in the right direction?
Thanks,
Thanks,
Re: HELP? Tial 35mm wastegate w/12 psi spring but I only want 6-8 PSI right now (Talon12bp)
you need to get a new spring. your spring is the lowest amount of boost you can run. a boost controller can only boost MORE than or equal to the spring rate.
Re: HELP? Tial 35mm wastegate w/12 psi spring but I only want 6-8 PSI right now (Foozball26)
I have a small green spring ( 0.5 bar ) 7 psi , I will trade with you if you want.
I need your large spring to combine with another small one I have to make around 17-18 psi
Modified by durkster at 10:46 PM 11/9/2003
Re: HELP? Tial 35mm wastegate w/12 psi spring but I only want 6-8 PSI right now (durkster)
Yea i think i might be interested in that. Is your spring from a tial wastegate? and will it fit the 35mm wastegate? is that all i need?
is it from a tial 38 mm wastegate, the 35mm and 38mm use the same springs,
I need this pretty soon ( I must have in my hand by the 20th of this month) .
All both of us need to do is undo the allen head bolts and remove the spring.
installation is the inverse ,install spring and reassemble.
The wastegate comes in sometime early this week.
Hopefully before tuesday. If i get it soon enough I can trade with you, how would we arrange getting it to eachother? I can overnight it once i recieve yours or whatever. just let me know.
Thanks, Bryan
Thanks, Bryan
post back to this thread when you get it, if i dont hear from you by wednesday I may just have to order what I need.
USPS priority mail should deliver in around 3-4 days max between virginia and texas
UPDATE
I have sold my spare wastegate with the 7 psi spring , however if you want to sell that spring ( 10 or 12 psi ) let me know
Modified by durkster at 5:46 AM 11/11/2003
UPDATE
Pro turbo kits here told me that they would trade me a 4 or 5 PSI spring for my 12 psi one, I think that might be a good deal. I just got my wastegate yesterday evening. I think i'll just do that. I appreciate the help though, and im glad there are people on here willing to help another.
Thanks again,
now should a 4 or 5 psi spring be ok, if later I want to use a boost controller and up it to say, 10 PSI? can i stick with the 4 psi spring in not, how much PSI can i up it befroe i have to use a higher load spring? Thanks
Thanks again,
powerdbygarrett
07-03-2008 01:50 PM
95srv
05-12-2006 07:09 AM
Cyber ITR
01-19-2004 03:38 AM
